Cases Thermaltake Level 10GT Full Tower Wide Body Gaming Case
Discussion in 'Hardware' started by mattbailey, 19 Jul 2011.
  1. mattbailey
    mattbailey What's a Dremel?
    26 Dec 2009
    Has anyone got, our using Thermaltake Level 10GT Full Tower Wide Body Gaming Case? Thoughts? It looks awesome!
    Bit-Tech you gonna test this one?
  2. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    I'm not sure you'll get many responses, because one'd have to be off one's trolley to spend over £200 on a Thermaltacky case, when the Silverstone FT02, multiple Lian Li cases, and Corsair's cases, among others can be had for the same or less. If you want an unpleasant looking case, you might as well have a HAF-X and at least have decent cooling as well.
    It's a shame, because it does have some nice features (hot swap drive bays, only one power input for said drive bays, etc), but it'd be difficult for me to overcome the looks.
  3. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    The original Level 10 looked awesome, but the cost was extremely excessive. The GT not so much, although I don't think it looks as bad as you say.
  4. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    i would actually buy if it was decent with cooling.....just to be different
  5. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    This. Thermaltake went wrong somewhere, I used to love their stuff but now I feel like they're so tacky and fisher-price...
  6. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Pcformat reviewed it a while ago so look on techradar.com (they said it was basically crap :)
  7. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Sadly a quick Google-Fu match revealed that the Level 10 GT, while being a very good case, is far too expensive for it's cooling capacity, and has a few critical errors in its' design.
    I'd say the only thing Thermaltake has gotten right ATM is the Frio. I doubt I need to go into detail with that thing.
