Hardware Thermaltake Toughpower QFan 650W
Discussion in 'Article Discussion' started by Tim S, 26 Feb 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Is there any particular reason why so many manufacturers (I know they are from the same OEM) are choosing to put the silly piece of plastic there? They much have done some research into it, because otherwise they wouldn't have changed from the norm. This must surely mean that there is some benefit to it?
    Great review though as always :clap:
    Why did you test it at 800W though? Its a 650W power supply isn't it?
  3. Tim S
    Tim S OG
    8 Nov 2001
    Good spot thanks, user error - the bottom portion of the template wasn't removed... :blush:
  4. dmak
    dmak What's a Dremel?
    1 Apr 2006
    agreed on the mutirail thing... When they first advertised this as a feature to look for a was a bit unsure, cause really, there are some single rail ones out their with like 60 amps... oh well I guess this is what the market wants
  5. Amon
    Amon inch-perfect
    1 Jun 2007
    Your workplace looks like it needs quite a bit of dressing up... :dremel:
  6. Tim S
    Tim S OG
    8 Nov 2001
    lol, that's not our offices - that's in Enermax's UK offices (where we borrow their equipment to test the PSUs ourselves).
  7. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    and they dont care that your testing other company's psus, which may be cheaper/better then there own?
  8. Tim S
    Tim S OG
    8 Nov 2001
    Nope, they trained us to use the machine and then they just leave us to it. The power supply manufacturers (collectively) actually want their units tested properly (i.e. with a load machine), so they're more than happy to support us where they can with allowing us to use the machinery. :)
Tags: Add Tags
