Hardware Thermaltake Water 2.0 Performer & Pro reviews
Discussion in 'Article Discussion' started by brumgrunt, 26 Sep 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Nice review, and also nice to see some common sense regarding the Arctic product... I've been using Arctic coolers for years on both CPU and GPU and ....
  3. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Will they fit the FM2 socket?
  4. David
    7 Apr 2009
    If the pro really does perform on par with a H100 it's a win for Ttake, surely, having fewer chassis compatibility problems?
    I do like the ease of use of these closed loop units (having used one on a temp basis, whilst rebuilding my loop) but the WC snob in me still wrinkles his nose at them. ;)
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    considering thermaltakes history with watercooling no one but the clinically insane should even consider this.
  6. David
    7 Apr 2009
    Wow, what an incredibly blinkered comment!
    These aren't made by Ttake, they're just re-badged Asetek units. :rolleyes:
  7. Risky
    Risky Modder
    10 Sep 2001
    A bit of a silly comment given that it's made by Asetek.
    TT have been around for a long time and have offere out a lot of products. Some of them quite hideous, some quite good.
  8. Krikkit
    21 Jan 2003
    Look pretty interesting, will a review of the Extreme be coming? Would be interesting to see what that's like.
    It'd be interesting to see a comparison between stuff like the H100 and a very cheap single 120mm rad WC loop. I know there's not much WC content for bit-tech because it's a huge area with many pitfalls, but it would be interesting.
    Also, the first graph of results has no numbers for the idle deltas. :)
  9. Combatus
    16 Feb 2009
    Sadly it does so with brute force and a lot of noise - the H100 is far quieter, cheaper and has fan speed control. If you only have a single 120mm fan mount, then we'd still suggest looking at other single 120mm fan coolers such as Corsair's H80. Out of the box the Water 2.0 Pro is only for those that can put up with the noise.
  10. Risky
    Risky Modder
    10 Sep 2001
    I just looked on Scan and the TT Extreme kit is almost exactly the same the same price as the cheapest EK kit, EK-KIT H3O - Supreme LT 240 EN
    Now an article comparing the two for performance and ease of setup would be very worthwhile.
  11. [EOCF] Tim
    [EOCF] Tim What's a Dremel?
    26 Oct 2005
    Thanks for your review Matthew. Just wondering if there is a review of the new range by Enermax. The ELC120-TB, ELC240. They look pretty good. Should be out in retail this week.
Tags: Add Tags
