I've read 2 people who were able to fit this radiator in a pc65. I was wondering if they or anyonelse can provide pics to see how they mounted it. I'm assuming it was a top mount, but my question is how did they manage to squeeze it in without the powersupply getting in the way? The powersupply I plan to get is the OCZ 520w powerstream. It's supposed to be around 6.8" deep according to OCZ's website. I don't know if that powersupply and the TC rad will fit. Anyone have any insights on what I should do?
If you find it doesn't fit you can always mount it in the bottom of the case. You will have to have the case raised more than usual though and it'll clog up with stuff if you have your case on a carpet.
Hows this????? The rad is a BIX2 but you can fit a 120.2 there as well, the only issue ive encountered was the psu has to stick out of the back with most "new" ones, ive stuck my Sparkle 400w in there as the depth isnt as much as my Tagen. ive also drilled a hole in the rear side just in front of the psu wiring loom and fed all the wires down through it for neatness.
