Cooling Thermolab trinity vs Titan fenrir V2
Discussion in 'Hardware' started by Fraser69, 22 May 2012.
  1. Fraser69
    Fraser69 What's a Dremel?
    25 Apr 2009
    Hello everyone, i was wondering if it was worth purchasing the thermolab trinity for AM3+. At the moment I am using a Titan Fenrir V2 on a 955Be overclocked to 4Ghz and I am worried a bit by the temperatures as at full load they are reaching 59 degrees. I have seen the reviews on Bittech for the Thermolab trinity , but would it bring my temps significantly lower or would I be better of staying with the Titan Fenrir?
  2. Fraser69
    25 Apr 2009
    Well I know i am answering my own question here, but I went ahead and bought a thermolab trinity. It is AMAZING! it shave 9 degrees of my load temps. 955 BE at 1.52 4Ghz. Idle 32 degrees in this hot weater were having , load at 50 degrees after 20 runs of intel burn test. Unbelievable!
  3. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    I have a 2600k and I was amazed that I was able to find such a short cooler with a 130mm fan. The Trinity fits in a small mATX case and gives me a gigahertz of overclocking headroom over stock without getting loud. It truly is a gem of a cooler.
