Other thin client help
Discussion in 'Software' started by urbtree, 29 Oct 2009.
  1. urbtree
    urbtree What's a Dremel?
    2 Oct 2006
    hi
    not sure this is the right section
    i`m running windows 7 on my main computer and have a little laptop pentium 3 256mb ram
    i would like to set up my lappy as a network bootable thin client. but i`m un sure on how to go about this
    can any one help me with this.
    i`m no pc noob but dont know any thing about thin clients
    not sure you need system specs but i`ll be happy to provide.
    thanks in advance
  2. craigp84
    craigp84 What's a Dremel?
    28 Oct 2009
    Fast Way
    Hi,
    I've had success with -->
    http://www.thinstation.org/LiveCD/
    But there are tons of different distro's marketed as thin client OSs, most of them come with bootable CD and even VMWare versions now so you can afford to try 10 or 20 different ones and find the one that makes most sense in your specific case.
    I tend to use MS RDP protocol for windows thin clients, it's pretty full featured (more than say tightVNC which is another popular choice). If you have very low bandwidth connectivity (say you want this to be a thin client over GPRS connection when out and about), there are other better options.
    Hope it helps
    urbtree likes this.
  3. urbtree
    2 Oct 2006
    thats loads of help mate thanks v much.
    what i`m after really is a way to run windows 7 on this laptop using the power of my main machine.
    is this possible or am i asking too much
    thanks again
  4. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    can kind of run it like that but only the latest version of RDP (windows 7) allows for aero to be used thu RDP.
    so from the laptop you will only get the basic theme and no graphics acceleration. So no games, etc.
    urbtree likes this.
  5. urbtree
    2 Oct 2006
    na i`m not after all the pretty stuff.
    the lappy is just to be sat in my office and used for invoicing and email (any office related tasks)
    and possibly a bit of music serving
    guys thanks so much for your help its given me plenty of research material
  6. urbtree
    2 Oct 2006
    ok so after a lot of good advice from here and various other places if settle on virtua box buy sun micros systems
    this is an awsome program
    its free
    had it running in five min
    installed windows 7 64 and it works perfect
    now i just have to work out how to get my lappy to access it
    any ideas?
    lap top runs xp but i`d like to do away with it really and have it boot straight to windows 7 if that even possible
  7. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Quick google turns this up.
    Bung it on your hard drive (you can network boot ... but why bother) and set up an RDP connection profile to your Win 7 box, and set it to auto connect (as per above quote).
    When it boots it'll bring up the RDP login prompt :thumb:
    There's even a LiveCD so you can test the performance of it.
    urbtree likes this.
  8. urbtree
    2 Oct 2006
    thanks you all so much for your help with this i have learnt so much from you all and will follow on from here
    unfortunately the screen on my laptop turned white last night with horizontal lines and now it wont work at all so its become some what of a moot point.
    gonna slam a rig together out of my parts stash and follow on from there when i get chance
    thanks again rep all round
