I've looked but i can't find any thin fans anywhere. I need a 80mm fan thats only 10mm thick. Its to put on the other side of the mobo blowing air on the back of it to keep stuff c00l Needs to be from UK sources
the minimum youll find is 15mm as that's usually standard with 25mm (and 38mm panaflos and papsts iirc)
I have a Panaflo L1A and Sanyo-Denky 80mmx15mm fans. Sunon and Orion also make them. Unfortunately, I don't know where you could get them in the UK.
i've got an 80 x 15 sat on top of my coolermaster.. might be worth gettin in touch with them or look thru rs catalogue or farnells catalogue .. both are online
