Modding Thing to hold the Intel CPU for lapping.
Discussion in 'Modding' started by Jayzilla, 4 Sep 2009.
  1. Jayzilla
    Jayzilla What's a Dremel?
    7 Jul 2008
    Hi every one, I have already lapped all my water blocks, when I going to lap my CPU I realized I no longer have that plastic holder came from the CPU, so what do I use to hold the CPU while lapping it? Any info will be appreciated.
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i used some black PVC tape when i did mine, as you dont have to worry about bending any pins!
    Last one was a home made water block for 939 :D
  3. Tangster
    23 May 2009
    I guess some thick cardboard or mdf with a Core 2 shaped hole in it would work nicely,.
  4. Big Elf
    23 Apr 2009
    I've lapped 4 so far and just use masking tape.
  5. Jayzilla
    7 Jul 2008
    Nice jobs U've done man, I hope I can get the result like your or close, I will use cardboard and PVC tape as you guys suggested, will post some pics tomorrow.:)
  6. Jayzilla
    7 Jul 2008
    Done.
    Double Posted.
  7. Jayzilla
    7 Jul 2008
    Dada.
    Before
    After
    G got hired as to hold my goodies.
    I used a pc of foam from the shipment and some painter tape just for my comfort while lapping, and it does but the results doesn't turn out as I expected, I don't think I will like lapping now. I am not a good photographer and any comments are welcome. Will do some extreme OC after I have done with my case and sleeving. Thanks guys.
  8. Matticus
    Matticus ...
    23 Feb 2008
    Looks much much better than before. Nice job.
    Can I ask what fan that is in the case reflecting off one of the blocks?
  9. boogerlad
    boogerlad What's a Dremel?
    27 Jun 2009
    ermm... It's not supposed to be shiny if you want best thermal performance.
  10. Jayzilla
    7 Jul 2008
    That is Gelid Wing, I think is a quality copyed from the Germany Nanoxia. It is very weak but looks nice compare to the others, very quiet as well.
    Isn't the shinier the better? I am still a newbie of lapping. Thanks.
  11. stonedsurd
    11 Mar 2009
    It's supposed to be _slightly_ rough. for best thermal performance.
    Shiny just looks good :p
  12. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    I just tape down the sandpaper and move the CPU....
