Things not to do with a £130 hard drive....
Discussion in 'Hardware' started by Will, 7 Oct 2003.
Thread Status:
Not open for further replies.
  1. Will
    Will Beware the judderman...
    16 Jun 2001
    ....Snap the tiny L shaped piece of plastic (about 10 x 4mm in size) off your 3 month old Western Digital Raptor hard drive, so that the data cable no longer clips onto the drive properly, preventing me from using the drive unless I use duck tape to bodge the cable in whilst resting the drive on a flat table.
    *sobs* :waah:
    The message that comes from my stupidity - take care with S-ATA cables. IMHO the interface is very fragile, I would say perhaps too fragile. My clumsiness is one thing, but it was hardly a great force that broke the tiny bit of plastic off. The cables themselves wiggle free rather easily, and could easily become dislodged over time (I have heard of on bloke who returned a PC to a system builder, it turns out that transporting the machine in the car had bumped the S-ATA cable off the drives connection so his hard drive wasn't connected).
    The ultimate irony is that Western Digital announced a new 'SecureConnect' cable not so long ago, claimed to boost the strength of the S-ATA connection by 5 times (so that obviously indicates they felt it was a weakness), This sort of cable clips on to the drive chassis rather than relying on a relative flimsy piece of plastic to hold the power and data cables in place.
    Look around and you'll see 'SecureConnect' being touted in the specs of WD's S-ATA hard drives, yet buying the cable to make use of this, which is about the only way I can conceive that will let me use my drive properly now its broken, seems impossible. Western Digital no longer even have the pdf detailing SecureConnects interface on their websites :wallbash:
    Anyway, a bit of a moan, its either find somewhere that sells these rare as rocking-horse-turds cables, or save another £50 until I can buy a replacement drive (thankfully they're cheaper now). Be careful with your S-ATA cables at the drive end! Don't knock them!
    :duh:
  2. Oo_Scotty_oO
    Oo_Scotty_oO What's a Dremel?
    11 Mar 2003
    I did the exact same thing too m8 :eeek: , but i got mine working again by sticking the little L in a sata cable & sliding the the conductors in to the cable . I also use a sata power connector to give it added robustness & carefully taping the 2 together & i have had zero problems with it since :thumb:
    It's a pretty shoddy design by WD (even by there own admission) & i think they should be replace these drives for both of us :p after coming out & saying 'sorry the sata connection designs are pretty crappy & weak so were redesigning them' :rolleyes:
  3. Will
    16 Jun 2001
    Might have to resort to using your ghetto skillz method to get the cable secure enough that I can have it in my case :thumb:
    I'm gonna ring up WD and have a whinge, they know its an issue as can be seen by them releasing the secure connect cable. I hope I can convince them to let me RMA the drive though...not hopeful mind, but its worth a go. I'll let you know how I get on mate :)
  4. Oo_Scotty_oO
    11 Mar 2003
    yep , please do , cheers bud :)
  5. Morphine
    Morphine weeee!
    23 Feb 2002
    one itty bitty teeny tiny drop of super glue will hold it from slipping, but you can still break the bond with your hands.
  6. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    manufacturers generally use hot glue to solve this problem.
  7. Foolio882
    Foolio882 What's a Dremel?
    1 Sep 2003
    Why is the cable coming out a problem? Unless it is on your boot drive, that would probably aggravate you, but on a storage drive (like mine) I just get a "Unplugged Hardware" box and I shove the cable back in.
    Still sucks that your broke, how exactly did you do it?
  8. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    is SATA hot pluggable or are you just lucky?
  9. Foolio882
    1 Sep 2003
    SATA is indeed HotSwappable!
  10. Will
    16 Jun 2001
    A 36GB drive isn't much use as a storage drive these days ;) so yes it is my boot drive :)
    Hot glue is a solution I considered, I just regard it as being rather ghetto style in all honesty - I'd rather see what Western Digital themselves say with regards to repairing the drive before I resort to that.
    As for how I broke it, I was overclocking and needed to clear the CMOS, anyway an IDE cable was folded down over the CMOS and under the S-ATA data cable, a quick tug on it to try and shift it and I notice the S-ATA cable is really wobbly on the drive. Broken :( as the IDE cable was quite tight underneath the S-ATA cable and as I pulled it up it pulled under it and snapped off the 'L'.
    Anyway, I rang WD this afternoon, explained the scenario and the bloke said that they didn't have a problem with me RMAing it for this issue (he said it was quite common). Anyway, halfway through taking my details he said his system had just gone down, so he noted my details with pen and paper and said he would get back to me asap (though I was calling 15 minutes before their call centre closes, so he said it might be tomorrow). I still don't have an RMA number but the guy didn't sound like he was fobbing me off...if he doesn't get back to me I'll ring them early tomorrow morning and try again.
  11. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Good news, hope it works out ;)
  12. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    SATA cables sux IMHO.
    Be careful with the power cables as well...
    Another thing not to do is have the power cable not in properly, and power up, only to see smoke, smell burning and have half the contacts on the power adaptor burn out.
  13. Shogun
    Shogun Banned
    18 Jul 2002
    thats why im holding off switching to sata. Going to wait a few months for them to iron out the problems first.
  14. Will
    16 Jun 2001
    Success!
    The German sounding bloke I spoke to before didn't ring me back or email me, so I rang again this morning before school.
    This time I spoke to a Spanish sounding woman, who was more reluctant to let me RMA it, but once I said the other person I spoke to yesterday said I could, she was fine with it once she'd asked him whether he said so.
    I also asked why, if the S-ATA connection is strong enough that if I break it its all my own fault, Western Digital strongly market a product to increase the strengh of the cable by five times - surely that indicates that the company feels there is a weakness? All she said was 'hmm yes, thats a good question we must answer' :hehe: so she said she would process the RMA for me and let me return the drive.
    One problem - the email with the details for the RMA is in German :duh: so I'm gonna have to try and get some to translate for me. But now I have an RMA number, it shouldn't really be a problem :thumb:
  15. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    Babelfish!
  16. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    good for words^ not whole sections of text as it's carp with gramma etc
    nice to know that WD realise there mistake and are willing to do something about it.
  17. Will
    16 Jun 2001
    I reckon Babelfish might get confused about the intricacies of different sorts of Polystyrene packaging materials and other such things an RMA usually for HDDs covers (they are very very strict about things like that).
    But anyway, I've found an English version of the packing instructions on WDs website, so all is good :)
  18. Tim S
    Tim S OG
    8 Nov 2001
    glad you're getting it sorted mate! :D
  19. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    shouldn't this belong in the "disaster mods" section? i know it wasn't an intentional mod, but malfoleos HDD destruction thread made it.
  20. Tim S
    Tim S OG
    8 Nov 2001
    Holy thread revival batman!
    It wasn't a mod or an attempted mod, it was an accident, so how does that mean it should be in Disaster mods?
    Also what was the point of your post, it wasn't relevant to the thread.
    Also either myself or Will would have moved it back when this thread was active, we're quite capable of carrying out our moderating duties without prompts. :grr:
    Closing as this thread was done and dusted a long time ago.
Thread Status:
