Rant Things that really need to be reinvented.
Discussion in 'General' started by Kronos, 15 Oct 2015.
  1. Xir
    Xir Modder
    26 Apr 2006
    Chinese electronics that come with a 3 wire lead but the earth isn't connected internally :D
    Common, very common.
    They just don't care, so what if someone gets a heartattack from touching a lamp, there's thousands waiting to replace him..
  2. theshadow2001
    3 May 2012
    Because you cover the majority of brands who make bread and save a few quid for more profit and a cheaper product.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    That cannot be true as my good lady eats a well branded bread and the slices are too big, in fact I don't think we have ever had a toaster where any makers bread slices fitted neatly.
  4. theshadow2001
    3 May 2012
    Ok then. Because the manufacturer doesn't give a flying hoot about your toast and its means more profit and a cheaper product which is more likely to sell.
  5. legoman
    legoman breaker of things
    28 Feb 2010
    I had the toast problem, got a Russell Hobbs one an it swallows a proper slice whole. Though when doing crumpets its actually too deep so have to pull the lever up to bring them to a grabbable height which I can live with.
  6. Nexxo
    23 Oct 2001
    Phillips once did a prototype toaster made of two adjustable plates of glass that heated up (coated with a transparent conductive layer). You could watch your toast as it browned, so you could terminate the process at just the right moment of golden brown crispiness.
    Magimix actually made a toaster with glass sides but it has a conventional heating element in the bottom. Just not the same.
  7. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
    cant think of anything right now but i will "see you next tuesday" :naughty: and let you know if i have come up with anything.. LOL
  8. Jehla
    Jehla Minimodder
    8 Jan 2010
    Just to echo Legoman, I've got the Heritage 4 slice and it can accommodate warburtons toastie thick slice.
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    This post contains much truth. Pretty much every cable and connector inside a PC is awful.
    Re: Toasters, we have a high-quality 4-slice badboy from Tesco (£25, so a true premium product :D) and it happily accomodates "long" slices of bread.
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    The need for a standby light on virtually every bit of electronics. I must have well over a dozen in my mancave/bedroom. A couple like the ones on my two Dell monitors, pulse for want of a enter word. Just charged my Black & Decker cordless drill twin batteries and there are two flashing lights.
    I appreciate that for somethings, perhaps chargers, these things are needed to indicate when a battery is charged but many are unnecessary.
  11. theshadow2001
    3 May 2012
    Its not a bad baseline concept though. The problem with the design is that the heat distribution would be uneven. If you had an isolated heat chamber and some forced convection of the hot air from the heat chamber into the toast chamber it would work great. Yes, a fan oven for your bread.
  12. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I can't believe I'm asking this but have you got a link? This problem has been annoying me for years and my toaster has stopped popping up so it's the ideal time to jump ship to a proper toaster.
    ...like doing it under the grill? I want this process automated!
  13. Guest-16
    Guest-16 Guest
    Thread Topic -------->
    <----------Toast Diversion
  14. legoman
    28 Feb 2010
    Ill find the model when I get home, i know its a four slicer.
    But Bindi, its toast!
  15. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    It's also Bit-Tech. If there's one thing that we're good at here, it's derailing threads :D :lol:
    Anyway, I too would be interested in a new and decent toaster - I hate having to turn the bread round because it's too big to fit in one go - so I have two okay-toasted sections top and bottom and one over-toasted section running across the middle...:sigh:
    legoman, how long before you can get home? :D :hip:
  16. legoman
    28 Feb 2010
    Ill be home about six, do you guys require photographic evidence of its toasting prowess?
    I can see the lastest purchase thread being filled with toasters now :D:hehe:
  17. ElThomsono
    18 Mar 2005
    I am legitimately interested in seeing this, I've never understood why toasters don't toast "edge to edge". I've even considered making my own XXL toaster but the complexity in the pop up mechanism has always put me off.
  18. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    This is the one I have. Toasting performance wise it's pretty good, not the best as one side seems to do a little more than the other, but it will do 4 slices of Warburtons super toastie in one go. SUPER TOASTIE!!!
  19. legoman
    28 Feb 2010
    Nosing on there, I seem to have found This beasty that looks suspiciously familiar. Ill check later though I dont recall a reheat feature on mine. But I can confirm it does swallow the Toastie bread perfectly well. Also used Bloomers in the past in there.
  20. Porkins' Wingman
    Porkins' Wingman Can't touch this
    23 Feb 2008
    Fixed
