Equipment Think about a new camera
Discussion in 'Photography, Art & Design' started by CrapBag, 15 Nov 2025.
  1. Krikkit
    21 Jan 2003
    I don't use the hop-up flash at all, it's crap! I don't have one or shoot with one yet. If I'm shooting in dark situations I'll just wing the ISO up and accept its limitations.
    But I can see why it's a useful fall-back to get you out of a tricky shooting spot.
    Congrats anyway, as said above share as you go, don't worry about how fancy they are
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Thank you everyone, especially Krikkit for steering me to the 7D on mpb.
    Arboreal likes this.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Camera has turned up and it looks to be in great condition.
    One thing is though it takes compact flash cards, I cant remember the last camera I had that took those, is that correct? Well obviously it is, I'm just surprised as I've bought a camera that's a lot older than my present one but better than the current one.
  4. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    From what I've read, the pros use CF rather than SD but couldn't tell you why. Speed, maybe?
  5. Arboreal
    21 Jan 2011
    Pro cameras use CF Express, which is a PCIe based storage medium. Not sure if it's related to old school CF, but it's a physically different card form that or SSD.
    It's faster as you say, and a lot more resilient to data loss than SD.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    So do I buy a CF card or are the convertors any good.
    I'm really torn on this camera, it feels amazing but it's five years older than the one it's replacing which I'm trying to ignore even though I know it's a better camera.
  7. Mr_Mistoffelees
    26 Aug 2014
    If, it shows all the signs of being well looked after and, the shutter count is not too high, try not to worry about the age.
  8. ModSquid
    16 Apr 2011
    My shutter count is probably insane, even though it's rarely taken for a walk. I auto-bracket shoot most of the time and continuous quite a bit as well.
    Oops.
  9. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    It looks amazing and the shutter count has only just broken 4k
    Mr_Mistoffelees likes this.
  10. Arboreal
    21 Jan 2011
    DPReview forums seem to like CF to SD adaptors so long as they are Type 2 to get the speed.
  11. Krikkit
    21 Jan 2003
    I bought a couple of CF cards for mine, the advantage you can have is if you shoot RAW+JPEG you can fire the RAW into the CF cards, then JPEG onto SD.
    You can just use the SD slot though, works perfectly fine.
    Don't forget to set up for back-button focus
  12. Gareth Halfacree
    4 Dec 2007
    I'm not a good enough photographer to shoot straight to JPEG - post-processing in Darktable is always a necessity!
  13. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Do you mean an adapter though as it doesn't have an SD slot?
  14. Krikkit
    21 Jan 2003
    It's only useful for filtering the dross quicker in JPEG previews :hehe:
    Oh sorry that's the most notable Mk2 feature, which as it turns out is what I have, I'd forgotten there even was one!
    If you've got some decent SD cards I'd use an adapter
    Gareth Halfacree likes this.
  15. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Yeh I had a feeling you might have had a MKII so have I made a mistake getting the earlier one?
    I mean its less than half of the price of the MKII 2nd hand.
  16. Krikkit
    21 Jan 2003
    I don't think so, it's still a great bit of kit. If you really gel with it have a think if you want to upgrade at some point.
    Obviously artificial comparisons are limited, but as a comparison:
    https://cameradecision.com/compare/Canon-EOS-7D-vs-Canon-EOS-1200D
    You've basically gone from the smartprice to extra special version of the same sensor package.
  17. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  18. Krikkit
    21 Jan 2003
  19. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    Have the Canon 7D and am very happy with it. Excellent choice.
    I just swap out 8GB CF cards as and when I need it as am paranoid about losing photos and have a USB-C adapter to upload them to Google Photos through my phone when they're nearly full.
    Main lens is a Sigma 28-200mm Aspherical, that and the bulky body makes for a good heft in the hand!
    Excellent camera, takes some getting used to the myriad of controls but I've always preferred physical buttons and wheels to touch screen doodads.
    133x CF cards are more than enough. 50MB/s read and 20MB/s write. Plenty of buffer in the camera anyhow. I put more faith in them than easily warped or lost SD cards.
    IanW likes this.
  20. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Um can I shoot using the screen?
    I used to just press the camera button and it would change from the view finder to the screen on the 1200D.
    Edit.....found it never mind lol.
    Idioteque likes this.
