Scratch Build – In Progress think_micro [complete(ish) 29-3-11]
Discussion in 'Project Logs' started by confusis, 8 Nov 2010.
  1. Cheapskate
    13 May 2007
    itty bitty, man!
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
    It is indeed. The almighty cheaps has spoken!
    The case is 2.6L. Quite small. When it's done i'll do the obligatory coke can shot/beer bottle shot to show it's true size :)
  3. mav2000
    mav2000 In Training
    16 Oct 2010
    That case is looking beautiful...
  4. confusis
    5 Jan 2006
    Thanks dude, a small update to do soon re: HDD rack. finding some screws now in my 1 litre tub of misc parts XD
  5. confusis
    5 Jan 2006
    HDD rack time! Hand formed with a cigarette lighter, and hand cut with my trusty dremelclone, I present the finest in ghetto racks!
    It holds two 2.5" HDDs (or SSD's when I purchase one). Still need to work out mounting to the case though without ruining the smooth external lines!
    Edit: Before somebody mentions I have fixed the wonky connectors on the SATA power lines.. :p
  6. confusis
    5 Jan 2006
    Size comparison to a normal 330ml beer bottle:
  7. KidMod-Southpaw
    28 Sep 2010
    This is getting sexy.
  8. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Haha DAMN this thing is small:p Looking at the first pics, i imagined myself something like mirco atx, but then saw how small it actually is xD
    Nice work dude!
  9. 123neonman
    123neonman What's a Dremel?
    28 Dec 2010
    This is amazing, I recently decided to build a ubuntu powered xbmc machine for my living room and decided on the same itx board because it is available super cheap. I had a few questions now that I have all of my parts amassed and assembled, it does not turn on - fail
    1. what is the pin out for the f-panel connector, I thought it was this standard pinout from intel.
    http://attachments.techguy.org/attachments/145236d1232942183/intel-front-panel-pinout.gif
    2. if my power supply is a 20+4 pin with a 4 pin cpu header do I need to do anything with the extra connectors? or just plug the 20 pin into my hp adapter i got on eBay?
    any help would be appreciated.
  10. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Cool lil project mate :D
  11. tkgclimb
    tkgclimb man it's all harder than it looks
    18 Jan 2010
    We're micro buddies :)
    But I have to ask, where did you get a pci-e extension that short? I need one.
  12. confusis
    5 Jan 2006
    What cpu did you choose? The pinout on the front panel is standard Intel specs.
    Should just be a straight plug and play with the PSU adapter, providing the adapter you bought is pin-for pin identical pinout to atx specs.. I bought a HP slimline PSU from a different model and the pinout was wack!
    Found it on fleabay, buying history is gone so can't find the vendor.. sorry!
    Thanks for the comments guys!
    To do:
    Buy a GT220 for gpu - my HD5450 doesn't work in this board!
    Save for a 2.33ghz Core2Duo
    Buy a slim 120mm fan for the side panel
    Mount the hard drive rack
    Devise a mounting system for the side panel
    Decide on vertical or horizontal orientation
  13. exexs
    exexs What's a Dremel?
    4 Mar 2010
    So small.. and quite.. Really good work here !
  14. tkgclimb
    18 Jan 2010
    It's okay, I realized I could shorten the one I had. Probably not as perfect as buying on but hopefully it will work.
    I'm keeping an Eye on this one, looks like your going to do some great work.
  15. confusis
    5 Jan 2006
    Re-did the rear panel and cut a small hole in the side for the GPU cooling. Ordering a HD4550 on Wednesday!
    Now to find some 1mm aluminium to cut a rear panel from!
    Also have pulled off all the white now, thinking of a new design.
  16. Amitlt
    Amitlt What's a Dremel?
    1 Feb 2011
    Realtek audio
    I'm interested in MOCA-AR motherboard also, but want to know does the built-in audio support DTS CONNECT or Dolby Digital Live features.
    Confusis, could you please check these options in the driver? Note, you should have correct audio drivers installed from HP and not from Realtek!
    Thanks.
  17. confusis
    5 Jan 2006
    watercooling? watercooling!
    AmitIT, the driver lists RTS on the RCA port, as well as Digital. No 'connect' or 'live' mentioned though.
  18. HoryBP
    HoryBP What's a Dremel?
    12 Aug 2010
    Orange plexi, watercooling, smooth edges. What elese do you need? :D
  19. confusis
    5 Jan 2006
    Prototype loop. Any comments?
  20. confusis
    5 Jan 2006
    W/C is in, leak tested and working..ish
    I upgraded CPU to a T5300, 3 watts more, and wow did the temps jump on even the air cooler!
    Went from 20 idle 50 load to 50 idle 80 load! Mustn't have been much more capacity in that lil heatsink.
    Finalised the W/C loop, is running right now with me using it! 42 idle 60 load. 34watt cpu.. must be the small bore.. hmm
