Thinking of my 1st Water Cooling build
Discussion in 'Watercooling' started by nescafe, 7 Aug 2019.
  1. nescafe
    nescafe Member
    8 Sep 2009
    Evening chaps. I have built a few pcs now over the years and I'm now thinking of dipping my toe into water cooling. Trouble is I never had any experience in water cooling although I do currently run a kraken x62. So my question is ... Is there anywhere I can read up and get all the info I need? ie what brands to stay away from?.... what's parts do you need?
    Thanks in advance
  2. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Someone here had a video showing a full watercooled build - that's the how; what to use I'll leave to those with actual experience in the field.
    EDIT:
    Just to verify I DID see it here, this is the post from the Modding Forum...
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    How much are you willing to spend and what are you wanting to cool? I have a old watercooling how to somewhere, really old but was really popular, give it a search.
    Edit: Here it is, oldie but a goodie :)
  4. nescafe
    nescafe Member
    8 Sep 2009
    I already have a suitable case and I'm wanting to cool my 7700k and gtx1080ti. Not sure on how much I want to spend yet though. Put it this way though. I don't want to spend money on a system and then wish I spent more if you know what I mean. lol
  5. Jeff Hine
    8 May 2009
  6. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    If you get new stuff, it's not cheap. You need: pump, reservoir, radiator(s), block(s), fans, fittings and tubing. Probably about £400-500 depending on component choices.
    I can highly recommend Watercool blocks. Superb build quality and outstanding performance. They're reservoirs are really cool too, but pricey.
  7. Bloody_Pete
    11 Aug 2008
    I just basically rebuild my whole loop (only meant to do part, and slipped to doing it all) and it cost around £500. CPU block: ~£60, GPU block ~£100, Radiator ~£100-£115, Pump&Res £115, fittings £50, tubing £20, fluid £10 (for premixed premium stuff), angled fittings £4-6 each, you'll want a few to make life easdier and the loop prettier, better fans upto £30 a fan. Honestly its a slippery slope, but really worth it!
  8. nescafe
    nescafe Member
    8 Sep 2009
    Thanks for the links and info chaps.
  9. NadavBee
    NadavBee New Member
    22 Aug 2019
    What are you trying to cool?
  10. nescafe
    nescafe Member
    8 Sep 2009
    cpu only at the moment
