Cases Thinking of Watercooling - What cases?
Discussion in 'Hardware' started by bdigital, 28 Apr 2011.
  1. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    Wait for the Xigmatek Elysium. It looks so good! :D
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Looks great. Although really dissapointed about the positioning of the holes for cable routing!!!
    I must have a tidy case, and with an ATX board i can see there being too many wires on show :(
    When is it due out?
  3. PyrO_PrOfessOr
    PyrO_PrOfessOr What's a Dremel?
    19 Sep 2009
    Personally I love my TJ-07 although I plan to be getting rid of it soon in place of something smaller - I'm moving for 7 months and want to bring it with me and water is just to insane to transport.
    The TJ-11 got a really good write up too. But if budget it your big thing then either 2nd hand or the Xigmatech...
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    i know what you mean, would have been good if they'd designed it with atx motherboards in mind as well *sigh* suppose we can't have everything D: its meant to be released around may time probably end of may, possible but theres not certainty on that
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    TBH watch that video again, you can see ATX gromets under the motherboard... Remeber he's testing a E-ATX motherboard...
  6. thetrashcanman
    18 Nov 2010
    ah your right there is one, suppose you could get a 24 pin underneath the motherboard, I think its a rampage 3 extreme, so not a proper e-atx board, but pretty much
  7. Bloody_Pete
    11 Aug 2008
    I'm basically sold on it I think...
  8. thetrashcanman
    18 Nov 2010
    ditto!
    edit, well actually I am sold
  9. bulldogjeff
    2 Mar 2010
    A modded Thermaltake mozart TX. I was counting earlier and it's possible to get 7 rads in it...lol
  10. balatro2005
    balatro2005 Minimodder
    19 Sep 2009
  11. bdigital
    10 Aug 2010
  12. bdigital
    10 Aug 2010
    Guys - quick question.
    Is it pointless me trying to acumilate water cooling parts from the marketplace until i know the case im going to be using?
    Ive seen a couple of bits (a rad for example), but i presume you cant really just start getting stuff without some planning?!
  13. thetrashcanman
    18 Nov 2010
    Probably slightly pointless, as different cases have different size rads you can fit in tj07 is a 480 and a 240, while the xigmatek is a 360 or a 3 x 140mm + a 480 or a 360, I suppose you could start searching the market place for pumps, tubing, fittings, block etc, but I'd leave the rad till you know which case your going to get :)
  14. bdigital
    10 Aug 2010
    Thank you - Il start watching out for some bits :)
    Do i also need to make sure i get the right fitting sizes on the pumps /tubes etc.
    wow i need to get reading up on this i think.
  15. bulldogjeff
    2 Mar 2010
    It's worth getting all the fittings, it's just the rads that need planning to fit the case. Basically you've got 3/8 fittings and 1/2 inch fitting. 3/8 tubing will go on to 1/2 inch but not the other way round. i like to go this way, you can get sharper bends and if you're using 1/2 inch barbs once the pipe goes on it's never going to come off.
  16. thetrashcanman
    18 Nov 2010
    yeah you do, I found it complicated to start with the sizes of tubing and compression fittings etc, but once you get your head around it its not to bad. I found once I'd worked out which tubing size I wanted it was much easier to get my head around, I used 1/2" tubing so you'd use either 1/2" barbs, or and I prefer them because to me they look more aesthetically pleasing, compression fittings, in which case you have to make sure the O/D (outside diameter) and I/D internal diameter are correct. so 1/2" tubing would be 1/2" ID and 3/4" OD check out pete's watercooling guide if you haven't already, its very helpful :)
  17. bdigital
    10 Aug 2010
    Brilliant cheers guys. Jeff are you saying you prefer to just stick with 1/2" stuff?
    I think that is what i plan on doing
  18. bulldogjeff
    2 Mar 2010
    I like to use 3/8 tubing on 1/2 inch fittings, especially barbs, gives a real tight fit. It's not as bulky as 1/2 inch either. Some people will try to tell you that you get reduced flow rates, but that a load of crap. As long as you've got a decent pump sending the juice around it makes no difference at all.
  19. thetrashcanman
    18 Nov 2010
    ^^ This, especially if your using barb fittings you want to get a nice snug fit, I think sometimes you can even get away with not using zip ties, which makes it look nice :) but then again if its your first time, maybe not :|
  20. GeorgeStorm
    16 Dec 2008
    I use 7/16 tubing over 1/2 barbs, no clamps/zip ties
    No problems so far, prefer the look to clamps and compression fittings aswell
    You can get everything apart from maybe rads
    But even then, most of the cases you're looking at can support a 240/360, so you can probably get one in safety. If you see a deal, snap i up ;)
