Displays Thinnest computer monitor?
Discussion in 'Hardware' started by OneSeventeen, 18 Nov 2010.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    We need to mount a few monitors in the surface of a table, just looking for the absolute thinnest we can find. (I'd be willing to buy laptop monitors if we could somehow put a controller/PSU 6' away from it)
    Any ideas?
    I would love to go under an inch thick, but that seems surprisingly difficult.
  2. Tangster
    23 May 2009
    Buy an LED monitor and take the case off since you're mounting it in a table anyway, you can put the power and circuitry somewhere else(although you'll need to extend the cables.
    Or buy some of sony's crazy thin OLEDs.
  3. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Just get a LED monitor [EDIT: beaten to it!] - i have a couple (broken) LCD's here with CCFL backlights and 90% of the depth is the ccfl!
  4. docodine
    docodine killed a guy once
    10 Feb 2007
  5. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    wait, you want the monitor to sit completely flat on a table? Thats a little bit of a problem since all LED monitors are thin because they hide most of their components like the PCB in the stand.
    I never disassembled a LED monitor yet so I don't know how long the cables that lead to the stand but it shouldn't be much of a problem.
    LED monitors are more expensive but I think the tinnest would be the Acer S243HL
  6. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    LED depends on the size for cost. I picked up two 22" monitors for $160 ea. Some standard LCD monitors sell for $200 plus in the same size... So go figure...
    Good luck on your project, you should post some pictures of your final product once you have it done.
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  8. saspro
    saspro IT monkey
    23 Apr 2009
    Strip a normal TFT down & you'll find the panel is very shallow.
    Mount the psu & control boards under the desk (or in the desk) and job done
  9. OneSeventeen
    3 Apr 2002
    I'll definitely try stripping some existing TFT's down, but it has been difficult finding one that I can relocate the PSU & control boards.
    The desk will be collapsible, so the surface needs to fold down and not have a bunch of electronics sticking out of it. (Basically the thickness of the surface will be determined by the thickness of the monitor I find)
    I will definitely post pics.
    We also have a 9" widescreen touchscreen going into a podium with a custom iPad mount. Should be a fun project to be a part of.
