Scratch Build – In Progress Thirteenth Monkey – Is that Steampunk?
Discussion in 'Project Logs' started by Flux, 17 Aug 2020.
  1. Flux
    Flux Minimodder
    11 Jul 2020
    Moving on. I intend to upgrade my Toaster to a Ryzen. That will leave me with an old crappy motherboard with an Intel i5 6500 and a Noctua NH-L9i cooler. Naturally, that has to go somewhere.
    So I came up with this design:
    This is just the tip of the Iceberg. I have some ideas for this project, but on the one hand I don't want to spill all my beans just yet, and on the other hand, I still have to convince myself that I can really build that. But there are more design clues to be taken from the 1995 movie "Twelve Monkeys".
    MaximumBubbleMods likes this.
  2. Flux
    Flux Minimodder
    11 Jul 2020
    This is a prototype for a leg. I am not entirely sure yet how I will get from this to the mirror finish metallic look in my renderering. I wil try vapor smoothing and all other finishing techniques. And maybe plate it with nickel? We will see.
    Dot_Kappa likes this.
  3. Cheapskate
    13 May 2007
    Did someone say 'monkey'?
    Cool! -but I see a few tough spots.
    The corner bits: getting that inner 90 degree cut would be tricky. Especially at the spot where it widens out and bends. It would be easier to bevel the wood and leave them flat on the inside. You could get screws in them easier too.
    Clearance for the cooler/wiring? I trust your skills, but DANG that looks tight. :lol:
    The logo thing looks pretty delicate. It might work better as an inlay.
    Edit: Ah, you ninja'd me. :lol: I keep forgetting about 3d printing cheat-mode. I thought you were doing the corners in metal.
    Flux likes this.
  4. Flux
    Flux Minimodder
    11 Jul 2020
    You are right. I want them to *look* like metal, but I am not yet sure how I will achieve that. I might even cast them in Pewter. Or do you say tin?
    I am aware of that. If all goes well, there will be a rather unusual cooling solution ...
  5. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    :thumb:
    Flux likes this.
  6. Flux
    Flux Minimodder
    11 Jul 2020
    Yes, thanks, I had already seen that. Definitely a possibility. I guess it's most important to get a very smooth polished surface before applying any kind of metal finish.
    Do you have any experience with that stuff?
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Yes you can.
    We are here to support you :grin: but I saw you've already made a prototype... Go on man :dremel:
    @Defyant Mods
    Does it last that kind of paint ?
    Flux likes this.
  8. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Houndeye? :cooldude::lol::rock:
    Flux likes this.
  9. Flux
    Flux Minimodder
    11 Jul 2020
    Thanks! And I guess I will be asking for a lot of support with this.
    :grin: After some googling i actually understood your comment.
  10. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    There is vacuum metalisation as well which gets a real layer of metal over the outside of the plastic, but not sure how much it costs, or if you send it to a company to metalise for you.
    Flux likes this.
  11. Flux
    Flux Minimodder
    11 Jul 2020
    Thank you, I will look into that.
  12. Flux
    Flux Minimodder
    11 Jul 2020
    I'm done designing the monkey wheel. Now I just have to make it like that in reality. Peace of cake, right?
    This one isn't quite there yet:
    Defyant Mods, kim and Cheapskate like this.
  13. kim
    kim hardware addict
    10 Jan 2016
    Wow, your Toaster is roasting the MOTM and you already designed another great project :dremel:... your ideas are really cool and totally original :thumb:...good to have you here :grin:
    Flux and Defyant Mods like this.
  14. Flux
    Flux Minimodder
    11 Jul 2020
    Thank you for the flowers. :happy:
  15. Flux
    Flux Minimodder
    11 Jul 2020
    Just to confuse you a little:
    Some mystery parts for this project have arrived today.
  16. Cheapskate
    13 May 2007
    Either your sink is plugged or you are lowering the suspension on your car. :p
    Flux likes this.
  17. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Twin bellows instead of fans?
    Flux likes this.
  18. Flux
    Flux Minimodder
    11 Jul 2020
    Strike!
  19. Dr. Coin
    13 Sep 2013
    Is that strike as in I've hit the mark and I am correct or strike as in baseball and it was a swing and a miss?
  20. Flux
    Flux Minimodder
    11 Jul 2020
    Er, okay, that was not as clear as I hoped it would be.
    Yes, that's exactly what it is.
