Graphics This cant be Right
Discussion in 'Hardware' started by tino1317, 14 Mar 2005.
  1. tino1317
    tino1317 What's a Dremel?
    13 Mar 2005
    Ok something is terribly wrong: Im trying to play counter-strike source with my new Geforce 6600 GT and i get an average of 7 FPS. Im hoping this problem can be fixed.
    My Specs are:
    Pentium 4 CPU 2.60 GHZ
    768 mb ram
    Geforce 6600 GT
    Directx 9.0c
    If you need to know anything else please tell me, now im kinda new to "graphics card knowledge" so if theres any settings that i should enable or anything i should download please tell me.
  2. Mister_Tad
    27 Dec 2002
    make sure that...
    -you are using the most recent drivers from www.nzone.com
    -you dont have excessive amounts of AA anf AF turned on in the control panel or in the game
    -you arent running in a ridiculous resolution
    (there are more possible reasons that it is acting up, but check those first and you can go from there)
    the setting with which you are playing the game would be handy to know
  3. tino1317
    13 Mar 2005
    How can i check how much aa and af im using? Im running it in 1152x864. And my video display for my computer is at 1280x1024.
  4. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    in the video options for the game go to advanced and tell us what settings are u using in there.
  5. tino1317
    13 Mar 2005
    Ok for th Model Detail: Low, texture Detail: Low, Shadow Detail: Low, Water Detail: Simple Reflections, Antialiasing Mode: None, Shader Detail: Low, Wait for vsync:disabled, Filtering Mode: Bilinear.
    I set my game to some lower resolutions and i cant get 15 fps now.
  6. Mister_Tad
    27 Dec 2002
    well the card is definitely capable at playing the game with those settings, provided that AA or AF is not enabled at driver level
    right click on the deskop, go to properties
    settings - > advanced -> 6600GT
    then go to "performance and quality settings" and make sure that antialiasing settings and anisotropic filtering are set to "application controlled"
    if theyre all good, then check what driver version you are using, you can find out by selecting the top item in the same menu that you see "performance and quality setting", the bit that will say GeForce 6600GT. The version of the driver is "forceware version" towards the bottom
    if it is anything other than 71.84, get this
  7. tino1317
    13 Mar 2005
    Yea its at everything you said =/
  8. tino1317
    13 Mar 2005
    Although my verticle sync was turned on in my driver settings, should this be turned off?
  9. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    should be application controlled. but you could also try off as this will help performance.
  10. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Any luck? is this only this one game or is it many games?(possibly a OGL bug or somthing)
  11. specofdust
    specofdust Banned
    26 Feb 2005
    Not sure if this is at all relevent, but I know someone who get's the same sort of problem in UT2004, with a 6800GT. lowest resolution, all graphics down, and under 10FPS, the rest of his system is all very respectable :sigh:
  12. tino1317
    13 Mar 2005
    Yea this is with most of the games i play, in CS:CZ i get 30 fps but ever since i got this card nothing has changed game play wise.
  13. Froggy
    10 Jun 2003
    if you run 3dmark 01 what score do you get?
  14. tino1317
    13 Mar 2005
    dont know it is =/
  15. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    hmmm I play UT2k4 with graphics on 'holy sh*t' on 1024x768 and get a framerate of minimum 70 and average 110, so it isn't the card. have you got all the drivers installed yada yada yada? Plus, reinstalling windows does help every once in a while.
  16. Froggy
    10 Jun 2003
    Yea i was also thinking drivers or a really bogged down windows install.
    Tino you are using the newest drivers right?
  17. pumpman
    pumpman Minimodder
    7 Jul 2004
    I agree with what someone said above turn vertical sync off
    I had a 6800 ultra with vetical sync on it crawled turned it off it flew
  18. tino1317
    13 Mar 2005
    Thanks alot you guys, it turns out that the installation guy at best buy didnt plug the card into my external power supply. Im only getting an average of 60 fps in Condition Zero but hey its better than before. Thanks alot!
  19. specofdust
    specofdust Banned
    26 Feb 2005
    Ah, smart guys, good to hear you got it sorted though :)
  20. smoguzbenjamin
    6 Sep 2004
    Ghehehehe what a prat. They should fire everyone selling videocards who neglects these kind of things and give me their job. Then I will have more money for modding. :eek:
