http://www.directron.com/860busb.html Can i run a amd setup in there? And do you know where i can find this case in the UK Thanks boys
would you please enlighten me on why it would not run an amd system, as i was unaware that this is case dependant... i am seriously intrigued...
Well someone pointed the case out to me and said it would only run Pentium systems, but as i mentioned, i should have read the info before i posted,
just as long as you get an AMD compatible motherboard you'll be fine, and just as long as the mobo fits in the case (which I've never seen being a problem, except on those tiny tiny HP or compaq cases). As to where to find it in the UK, I don't know, sorry.
second blurb: "Compatibility: Almost all standard ATX motherboards should fit in this case including Athlon motherboards from FIC, Abit, EPoX, BioStar and Asus although this case itself is not Athlon approved"
The closest I have seen to this case in the UK is the hydraulic case Kustoms PCs sell......... See Here However this is the old style one, without the curves on the front bezel Directron speak of. I have seen one of these at work and they are big, quality cases indeed!
