This hardware??
Discussion in 'Hardware' started by richman, 9 Jun 2004.
  1. richman
    richman What's a Dremel?
    17 Sep 2003
    What do you think of this hardware for a server would u change anything.
    Mobo
    CPU
    RAM
    Hard - Drive
    Richman
  2. Dayains
    Dayains Notamodder
    18 Dec 2002
    server 4 what exactly?
  3. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    4 serving stuff. errr, im guess its not going to be a very big server...
    It would be ok for doing small jobs but its not particualry powerful, when i think of a server i think dual processors, not AMD 1600. But if you just need a serve for the odd picture and your own small site it should be fine. Usually the internet connection will be your limit, rather than the PC
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    I'm guessing he means some sort of network server tbh...
    have a 1gig, 128mb ram here thats been used as a games/file/LAN server for ~ 8 months no probs.....
  5. richman
    17 Sep 2003
    It isnt a pc that lived in a data center iam not going to have a server in my home with dual xeon processors for god sakes :duh: all i want to know is what that mobo is like if anyone has one or if anyone would reccommend another one.
    Richman
  6. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
    You'll need a case to put it all in, and a PSU to power it... :D
  7. richman
    17 Sep 2003
    This stuff i already have :) i just posted the stuff i need to "buy"
    Richman
  8. Carlk
    Carlk What's a Dremel?
    10 May 2004
    yeah, u wanna change the ECS board, and the maxtor hard drive :thumb:
  9. richman
    17 Sep 2003
    Any Suggestions m8
    Rich
  10. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    No don't change the hard drive, I have run desktop Maxtors as server drives before they are pretty damn solid tbh.
  11. richman
    17 Sep 2003
    I have had a maxtor before and they are quiet good from experiance. What board should i change to tho.
    Rich
  12. Highland3r
    25 Jul 2003
    Theres nout wrong with the ECS boards IMO, ok they are cheap, but much much better than the PCchips boards..... Cant forsee a massive problem tbh...
  13. richman
    17 Sep 2003
  14. Guest-16
    Guest-16 Guest
    Anything, something good though as it's the foundation of your computer and usually the decider whether it is ultimately uber stable or not.
  15. richman
    17 Sep 2003
    I might wait get the HDD, RAM, CPU Then wait till next pay day and get a better mobo.
    Richman
  16. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
  17. Prophet
    Prophet Minimodder
    19 May 2003
    Aria are a bargain on some of the stuff u can pick up :) Those duron 1800s arnt to bad and if u only want to serve some small files, host some ****e, ICS then thatd be fine :)
    The ECS mobos are ok but like said above, nothing hurts with spending a lil extra and getting a great mobo.
    Proph.
  18. TMM
    TMM Modder
    12 Jan 2004
    switch out the HDD for an 8mb one
    im guessing the mobo is a kt400?
    edit: no usb2, its a KM266 chipset. personally id go for a kt400 or kt600, or even an Nforce2 if you can find one cheap one (probably WAY out of your budget tho lol)
    did you go for a mATX board on purpose? or was it just becuase it was cheap?
  19. richman
    17 Sep 2003
    WOW that is some cheap kit cheers for the heads up on that, the duron 1600 will be fine i think for what i need, all iam going to be doing is having hte server store and serve my files (E.G MP3, Word Documents, and EXE Downloads) This will also be the home of all the user profiles and things, it wont be under alot of stress i dont think.
    Richman
  20. Tim S
    Tim S OG
    8 Nov 2001
    if you can find a 256k cache chip, I think that'd be better suited. I run a Tbird 1000 with 1gb memory in my file server.
