Graphics This may seem dumb but...
Discussion in 'Hardware' started by Bloodburgers, 8 Oct 2009.
  1. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    I want to up grade my graphics card however have very limited money i currently run a gddr5 variant of the 3870.
    Recently i saw the offer overclockers have on for the 3850 X2 for 50 notes. Is this the same as a 3870 x2 because iirc the 3870 x2 used two 3850 chips.
    I only game at 1680 x 1050 (or whatever i cant remember what it is exectly) and i only have a low end psu so going for a more up to date card would mean upgrading that too.
    Will i see definate gains with the 3850 x2 over my current card??
  2. Krikkit
    21 Jan 2003
    That's an interesting question.
    The 3850 and 3870 are very different beasts, although it's actually pretty tricky to find a decent review of it.
    It sounds to me like the cheap 3850X2 would be a reasonable option for an upgrade, it's worth noting that it is a 2*3850 GPU card, whereas the 3870X2 is 2*3870 GPU's.
  3. Bloodburgers
    30 Apr 2009
    i was always lead to believe that the 3870 X2 ran two 3850 chips? maybe i was wrong. hmmmmmmmmm
  4. Krikkit
    21 Jan 2003
    According to the original review of the 3870X2 (RV680) it's two 3870's nailed together. I didn't know either, but there you have it. :thumb:
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    they were kept in family so the 3870X2 used 3870 cores.
    its only nvidia that decided to slap two GTX275 cores together and create a GTX295, altho asus recently did it the way it should be with dual GTX285's.
  6. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    scratch that
  7. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    didnt the 3870 x2 and 3850 x2 perform horible in gaming?
  8. bagman
    bagman Minimodder
    18 Apr 2009
    yes they did a 9600gt is better than a 3870x2
  9. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    You could look at getting a faster single chip card rather than the x2, unless you can find a really good price on it. Single chip card are less reliant on drivers and their performance if far more reliable.
  10. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    If you're short on money, you shouldn't be making such small upgrades. Wait untill you can afford an equivilant model from the next generation of cards.
  11. tk421
    tk421 Idiot.
    15 Jan 2002
    better yet, drop $90 on a 4850.
    i havent had any problems with mine, been running everything i throw at it full detail @ 1680x1050.
    this was stepping up from a 8600gt ... HUGE difference.
  12. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
