Cooling Thorite codes
Discussion in 'Hardware' started by :: kna ::, 28 Jan 2003.
  1. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Ok, dumb question time, but it'll help me work out my sizes better..
    If you were buying two adaptors from Thorite:
    http://secure.thorite.co.uk/Index_Male_BSPT_Hose_Connector_164.html
    ..to fit in out/intake of an Eheim 1048, which ones would you buy, and why?
    I understand all the sizes etc, but I can't work out for the life of me why what I ordered wasn't what I expected.
    All info greatly appreciated. :)
  2. Pug
    Pug What's a Heatsink?
    16 May 2002
    Well, the threads on the 1048 are G 3/8 and G 1/4.
    That means it's a BSP Parallel thread of 3/8" and 1/4".
    So, all you have to do is tell us what bore size you're after and we're golden. :)
  3. :: kna ::
    15 Mar 2001
    Doh, I'm not helping myself by not putting what tubing I'm using either :D
    3/8"/8mm (I know 8mm isn't quite 3/8" but it fits snugly)
    So by my guessing, it's:
    BMH38 and BMH1438
    If that's right (confirmation welcomed), I think they may have sent me the wrong things :(.
  4. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I had the same problem. My first order wasn't what I expected either.
    They were most helpfull when I gave them a ring and explained the problem. They're also aware of how much of there stuff is being used for kooling goodness. :clap:
    You can get some kits here?
    http://www.overclockedpc.co.uk/default.php?cPath=38_24
