Graphics Thoughts on GTX 670 4GB SLI
Discussion in 'Hardware' started by LordLuciendar, 11 May 2012.
  1. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    You seeing any difference man, cos if not I am wondering if I should still buy 4 4gb 680's now
  2. Guest-44432
    Guest-44432 Guest
    66FPS was the absolute min I could get on the map running through every nook and cranny blowing everything up in my path!
    I will now revert back to Drivers 301.10 and do another test.:)
  3. Guest-44432
    Guest-44432 Guest
    David likes this.
  4. lysaer
    15 May 2010
    fairly identical then :/.
    I can see there being a lot of upset 680 owners if this stays this way
  5. Guest-44432
    Guest-44432 Guest
    Well someone will need to show a 5min run on the same map with 2x GTX 670's so we can compare results.
    The video on page 1 is a common flaw of how not to test a GFX card in a game, as it doesn't replicate the true running of a game.
    So half of these benchmarks don't show real world performance.
    Anyone with 2x GTX 680 2GB & 2x HD7970 want to run the same test for comparison?
  6. lysaer
    15 May 2010
    I can do it later on 7970 when I get home, but it does show that there is not a difference in driver versions at least not enough to affect the 680's so it is worrying why the 670 is so fast
  7. rollo
    rollo Modder
    16 May 2008
    4 fps min is the dif between playable and not in some circumstances id say its a pretty big difference. As an online gamer 62 min vs 66 the extra 4 fps means less lag at moments that might get you killed.
    also looking at those graphs
    the newer drivers look alot smoother than the older ones only 1 dip below 80 vs a good number on the older drivers thats gonna be noticeable to some gamers out there.
  8. lysaer
    15 May 2010
    yeah but it's not a big enough difference to justify the prices, I mean yeah I don't really care about price if I want the fastest I get it but it just seems incredibly lack luster of the 680 at the mo
  9. Andre_B
    Andre_B Minimodder
    17 May 2009
    I'm a bit upset at the moment. I really do hope that the 680 drivers improve, otherwise I feel robbed.
    Sent from Bittech Android app
  10. Parge
    16 Jul 2010
  11. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    that 680 looks tempting but i just hate the look of the jetstream card
  12. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    i predict they'll sell a lot of cards like this
  13. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I think it might be simply to shift the die-binned 680 stock, all the stuff that could be made into good 670 stock. Perhaps, should AMD ever overtake the 680 with the 7970, they'll "magically" Release some Bios or Drivers that suddenly up performance by x percent.
  14. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Strangely, for the BF3 multiplayer review, hard ocp, gives the 670 higher fps than in bt's review of on line mp at the same res/settings.
  15. rollo
    rollo Modder
    16 May 2008
    cant say reviews are ever accurate with graphics cards
    they either use timed demos or play parts of the game that are not really graphically demanding
    dont see alot of bf3 64 player testing going on for example
  16. .//TuNdRa
    12 Feb 2011
    What we need is a system in games similar to Ye Olde Homeworld/Homeworld Cata recording system, that produced an instructions file, which you fed straight back into the game and it replayed the entire match under realtime-rendering. Sadly; I doubt file sized on those things would be as good as the 200KB that those old replays took up.
  17. Guest-44432
    Guest-44432 Guest
    Here you go! :)
  18. GregTheRotter
    9 Aug 2008
    I wouldn't really call tdm a good representation of the game as a whole, but hey.
  19. Guest-44432
    Guest-44432 Guest
    Can't please everyone! :rolleyes:
  20. GregTheRotter
    9 Aug 2008
    Nope, shame you feel that my comment was worth that emote though tbh. I'm not exactly wrong either.
