Build Advice Thoughts/suggestions on new build basket
Discussion in 'Hardware' started by Daveg, 31 Dec 2012.
  1. Daveg
    Daveg What's a Dremel?
    25 Sep 2012
  2. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Looks quite good to be honest, i would add an ssd though, even if it is only 64gb it just means your pc will boot in a fraction of the time.
    Also, once you get to 20 (constructive) posts you can get free delivery from scan :thumb:
  3. littlejames
    littlejames What's a Dremel?
    5 Nov 2012
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  5. Guest-16
    Guest-16 Guest
    Also consider:
    Asus P8B75-V
    i3-3220
    Boot SSD
    Single/dual thread performance will out-do that AMD FX, but it'll fall behind on 4-6 ALU/3rd FPU performance
  6. littlejames
    5 Nov 2012
  7. mrbungle
    20 Sep 2004
    Ditch the FX.
    Can get a i5 and cheap mobo for similar money.
  8. S1W1
    S1W1 Minimodder
    25 Mar 2011
    Considering that you're getting a thoroughly decent discrete graphics card, you'd be better off with an Intel i3 3220 with the motherboard that Bindi suggested above.
    The other recommendation I would make is a 64GB SSD to use as the boot drive - even if that means breaking your budget, it really, really is worth it - even if you just get the cheap Sandisk drive for £43.97. That said I would go for the Crucial M4 for the extra £12.
    The rest looks great.
  9. Swanny
    Swanny What's a Dremel?
    23 Nov 2012
    I have just done a Similar build myself, I running full AMD including an XFX graphics card, really is good. Just remember to register the XFX within 30 days of purchase to get your lifetime warranty.
    The new Piledriver AMD chip is great, i would suggest an SSD but depends on your budget, it boots and retrieves data faster but if you can put up with a HDD it will still be a good machine :).
    Good to see some one else not jumping on the Intel band wagon.
    you wont be disappointed.
    Swanny
  10. mm vr
    18 Nov 2007
    The system in my sig pulls around 330W from the wall on full load (Prime95 + FurMark). A 500W unit would leave plenty of headroom for fans.
