Thread Filtering Problem
Discussion in 'Feedback & Suggestions' started by GuardianStorm, 2 Jul 2007.
  1. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Hey, just noticed a problem with the thread filtering:
    go in to the Project Logs section and try and look at all scratch builds since the beginning (select beginning at the bottom of the page, and scratch builds at the top) and you cant. Filtering will only view the last months threads, and viewing all from the beginning clears the filter settings.
  2. cderalow
    cderalow bondage master!
    23 Jan 2002
    i have to say, in general the new setup is annoying...
  3. RTT
    RTT #parp
    12 Mar 2001
    Just click on Scratch Build filter, then once it has re-loaded, go to the bottom and select "from the beginning" and you'll get all scratch builds since forever.
    By the way, you can also edit your default preferences to "from the beginning" in your profile :)
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    This was a bug i didn't have time to fix on Friday. I fixed it this morning though :thumb:
  5. GuardianStorm
    26 Apr 2005
    thanks Jamie & RTT
