alright all, a quick question, how can I thread wholes that I have drilled in the bottom of a case (its an old one, im practicing on it) its steel so its tougher, the type of screws I would be using are the same as the ones for mounting t'mobo, but these screws aren't self tapping. any ideas?
Go to B&Q and pick up a set of thread taps - I think they cost about a tenner. Tapping holes is easy, you just need to make sure you start straight, go forward half a turn then back quarter of a turn, and keep going till you're done.
If its the bottom of the case, it might not be thick enough. If it is sheet metal, its easier to mess up the tap then with a big chunk of stuff.
