Modding Thumb Drive Painting
Discussion in 'Modding' started by Taznc, 21 Jul 2005.
  1. Taznc
    Taznc What's a Dremel?
    4 Jun 2004
    I have a Lexar JumpDrive Secure and I would like to paint it because the paint has already worn off a lot and it looks old. I need paint that will not wear off easily because it is in my pocket a lot. I also am not quite sure of how I would paint it, I imagine sand it a lot and then put a couple of coats on.
    The black part is ruber-type and I would not be painting that.
    Thanks in advance.
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Go to your local auto parts store and get some vynal dye. It seaps into the plastic and dyes not only the top layer but sinks down and dyes under the plastic. Very hard to wear this stuff off, its made for car seats and dashboards.
  3. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    yup i second that :thumb: :thumb:
  4. Taznc
    4 Jun 2004
    Thank you :thumb:
    Are there different types on vynal dye or anything? Are any brands better than the others?
  5. Taznc
    4 Jun 2004
    Also, do I need to sand it for vinyl dye? If so, what grit? \
    Also, is there a difference between vinyl dye and vinyl paint?
    Thanks
  6. Taznc
    4 Jun 2004
    Is this what I am looking for? There is no picture but there are many Advance Auto Parts near me...
  7. [<x>] Kiyusoma
    [<x>] Kiyusoma Deus Ex Machina
    16 Jun 2004
    or just go to your local walmart and pick up a can on krylon fusion in a spray can
    about 4 bucks.
    you might wanna lightly sand it to make the paint adhere better
    use a light grit just to get any grime and old paint off, but don't put deep gouges in it
    don't forget to mask off the rubber parts before hand....
  8. Taznc
    4 Jun 2004
    Thanks!
    does krylon fusion work the same way as in it soaks into the plastic? with my thumb drive on my key chain, it gets a lot of scratches....
    I cannot seem to locate krylon fusion on walmart.com...should it be there?
  9. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    No, it doesn't work like vinyl dye. I know this from experience.
  10. tm36usa
    21 Jan 2004
    Yeah krylon fusion is really a joke. It doesnt last longer than anyother pain to plastic, you need they vynal dye. I got my from an Advanced Auto parts in a small town but I have seen it at Napa and other auto stores. Good luck
  11. Taznc
    4 Jun 2004
    Okay thanks, there are both Advanced Auto Parts and Advance Auto Parts near me hehe....the only 2 auto stores i can think of,
    about how much should it cost me to get enough to paint a thumb drive?
  12. tm36usa
    21 Jan 2004
    You would only need one can, and you would have alot left over. My can cost like $3.88 USD so it shouldnt be anymore than $5.00 . Hope this helped.
  13. Taznc
    4 Jun 2004
    Oh, ok thanks...
  14. theagent
    theagent What's a Dremel?
    4 Nov 2003
    yeah, i painted a thumb drive with that fusion stuff and it wore right off.
    -agent
  15. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    I painted one of my USB drives, I went the old fashion way. I taped up what I didn't want painted and primed and painted. Make sure you put on a clear cote. As you can see I didn't use the fusion plastic paint.
    My paint job is still lasting and my USB drive spends allot of time with my keys in my pocket.
    The only reason I really painted it with normal car paint is because I had some left over from one of my projects.
    I strongly recommend going with the Fusion plastic paint though.
  16. tm36usa
    21 Jan 2004
    I would still say go with they dye beacause there is no chance of it wearing off. And you dont need to clear coat. The Krylon Fusion is really a joke. It doesnt "chemically bond" with the plastic like the comercial says.
  17. mattthegamer463
    26 Nov 2004
    i need to get some vinyl dye for my usb key. the company only made them in purple (purple!!!) so i need to change its colour. the kids at school would point and laugh*, theyd all say " look at the kid with a purple usb stick!" so i need to change it.
    *PS. that didnt actually happen.
  18. Graffix
    Graffix What's a Dremel?
    5 Jul 2005
    LOL a bit random but i can go with that :worried:
  19. mattthegamer463
    26 Nov 2004
    lol sorry i sometimes get a little off topic with my posts.
