Thunderbird 1.2 @ TT Volcano 12 (No Fan)
Discussion in 'Hardware' started by JohnFish, 2 Jun 2006.
  1. JohnFish
    JohnFish New Member
    12 Oct 2003
    Hey guys. I have an old thunderbird 1.2 ghz with a thermaltake volcano 12 in an htpc box I am building. I wanted to ask whether I can get away with no cpu fan (just the heatsink) and only try to have a decent airflow in the case. Thx
  2. Krikkit
    21 Jan 2003
    Well according to Wiki, the TDP is ~66W, so I'm not entirely sure if you can get away with a passive system. Maybe you should use a fan controller (via temp monitoring) to switch the fan on when it's hot and keep the fan off when it's idle. :)
  3. hughwi
    hughwi Well-Known Member
    23 Dec 2003
    Ive got an old 1.2t-bird rig, and its got some sort of 60mm coolermaster HS+Fan combo on it, and its bloody hot! gets into the 70's when just surfing the web, room temps are about 23-25. Although they were built to withstand much higher temperatures than current chips, i think they are rated up to 100!
  4. hitman012
    hitman012 Active Member
    6 May 2005
    Those old T-Birds are hot - it's extremely unlikely that you'll be able to run it passive. You could probably replace the heatsink fan with a quieter model, but without a fan it'll most likely overheat.
  5. JohnFish
    JohnFish New Member
    12 Oct 2003
    I cant put the fan on the usual way, ie over the heatsink, cause there is no space. I can put it on the side (most likely I ll do this) or replace the hsf with another one (slimmer).
  6. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    I am currently building a Linux box with which I am going to attempt to cool passively!but its only a celeron 500 or so, and when I had it running for 4hrs., with no fans on whatsoever it got to about 35deg...
