Cooling Tightening waterblock barbs.
Discussion in 'Hardware' started by Arthur, 20 Feb 2010.
  1. Arthur
    Arthur Comment is over there ----->
    24 Nov 2009
    Hi there,
    Any rules to follow here such as torque limits etc as i dont want to crack the block or strip the thread in the barbs lol.
    Tips or advice very welcome.
    Thank you.
  2. Krikkit
    21 Jan 2003
    What materials? I don't think there are any specific values, but metal barbs on plexi tops are pretty delicate things. I'd use some o-rings and PTFE tape to try and make sure I didn't have to tighten it up too much.
  3. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    I've always done it finger tight. Never had an issue
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Finger tight always worked for me.
  5. Arthur
    24 Nov 2009
    Sorry for omitting such an important piece of info.....materials are plexi block & metal barbs.
    Cheers for the replies all :thumb:
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    PTFE tape on the thread with help form a seal, and finger tightening should be fine.
    When i first started out i used a socket set to crank them home, only to then find cracks forming, lesson learn't the hard way i guess.
    I still nip them up with a adjustable spanner but nothing major.
