News Tilera unveils 100-core processor
Discussion in 'Article Discussion' started by CardJoe, 29 Oct 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. trig
    trig god's little mistake
    10 Aug 2006
    i dont get this...100 cores...25 times what we have now, and only 4 times as powerful? so, and i haven't looked at intel's roadmap recently, but i would imagine by 2011 they will have an eight-core cpu at least in the works, this 100 core chip will be about as powerful as that? theoretically?
    i know i probably dont get where this has a significant advantage somewhere...just seems like a waste...
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    it all marketing BS
    4 times as powerful
    at what some specific highly multi threaded app how doe sthis compare to cuda which is the current equvalent
  4. Radical_Monkey
    Radical_Monkey Dremel > Lightsabre
    27 Feb 2008
    This would be very useful in the field of grid computing and cloud computing, saving a shed load of space and less cooling for hopefully similar or better performance. But as yakyb said, GPUs will be competing with these CPUs head to head and cuda has had a huge lead on it. Infact where I work we're looking into using nVidia GPUs for our grid solutions, so I think its got an uphill struggle.
    Saying that, if they are supremely power efficient then that could be the ace up its sleeve that it needs....
  5. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    http://en.wikipedia.org/wiki/Amdahl's_law
    This is why do dont get a 25 fold increase in speed. Also bear in mind the cpus are clocked alot slower than other cpu cores.
    the biggest news is the performance per watt. Increasing this by an order of magnitude is going to make cloud and server providers sit up and take notice.
  6. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    this is actually fairly old news, I mean really old news, Im not sure if it was this company but a 100core CPU has already been made and as for performance it was more focused for the manycore concept then the multicore concept that we know now.
  7. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Sounds a lot like Larrabee. If OS's have to add support for masses of CPU's for that, why not for this?
  8. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    I wanna see what the Performance tab in Task Manager looks like with that! ;-)
  9. identikit
    identikit Minimodder
    5 Jun 2004
    Forget about the 100cores, the GHz, the watts etc. It's all about the architecture. Intel made an 80core CPU running at 10GHz years ago IIRC. The thing stopping them was the non-conventional architecture. Your hardware is only as good as the software you can run on it.
  10. Chocobollz
    Chocobollz What's a Dremel?
    25 Dec 2008
    No, even if they have an ace up their sleeves and successfully make a three of a kind aces, I'd say any GPGPU (ATI or NVIDIA) will at least beat them with a fullhouse, or a higher hands :p
  11. Bazz
    Bazz Bit of everything geek
    7 Oct 2009
    You are assuming it is being compared to a Intel and AMD chip then yeah??
    What about other CPU's commercially avaliable??
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    You mean something like this?
  13. ChaosDefinesOrder
    6 Feb 2008
    Can't use YouTube here at work so can't see that for now, but I think it's the AMD Opteron with 16 cores isn't it? Seen that, with the task manager spread over two windows full of "cores" - still wanna see what the tab with 100 little boxes looks like! Would be epic!
  14. identikit
    5 Jun 2004
    Vid description: Intel's Kennedy Brown and IBM's Kevin Powell show you a sneak peek of an 8 socket, 64 core, 128 thread IBM server based on Intel's Nehalem-EX processor.
    :jawdrop:
  15. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Three cheers for innovation. Ok, maybe its not brand new as some people have pointed out. But going against the norm is one way that we can advance technology.
    Good job Tilera.
  16. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    I wonder how this compares to GPGPU tech. On former side you can use existing hardware and plug more GPUs in to scale (like nVidias Tegra) or have a customised operating system and and entirely new hardware to support these chips...
    Hmmmm.
    I'm working off the assumption that these chips are built to handle massively parrallel but simple tasks, and thus have drawn the comparison to CUDA/OpenCL.
  17. TSR2
    TSR2 What's a Dremel?
    19 Aug 2009
  18. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    So these are x86 cores?
    I think sticking with fewer, more powerful cores for now will suffice.. With CUDA/OpenCL for any massively multithreaded applications.
    Yeah, that's probably better than a 100-core CPU... Since with GPGPU you get way, way more "cores" to thread through.
Tags: Add Tags
