Apple Time Machine & Dual Hard Drive Enclosures
Discussion in 'Software' started by Sleepy_Sentry, 6 Aug 2008.
  1. Sleepy_Sentry
    Sleepy_Sentry What's a Dremel?
    30 Jun 2008
  2. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Considering that the enclosure treats the two hard drives as one contingous blob, I would say no.
  3. koola
    koola Minimodder
    11 Jul 2004
    For that price, I bet it only supports RAID 0 and JBOD. Would still do fine for TM though.
  4. Sleepy_Sentry
    30 Jun 2008
    No, the drives can run independently.
  5. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    If that's the case then name them differently, "TimeMachine" and Bob, or something like that. One time machine takes over a drive when you plug it in it will use it.
  6. Dizman
    Dizman What's a Dremel?
    6 Jul 2006
    Even if you can't run them independently, time machine doesn't take over the whole drive. If you can use HFS+ for everything (time machine requires HFS+), you could just run them as a big JBOD array and time machine will just eat up as much space as it needs.
