Build Advice Time to upgrade....?
Discussion in 'Hardware' started by Abbo, 19 May 2015.
  1. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    It has been quite sometime since I have been on the forum, but feel it's time that I need to visit for some advice.
    Back in 2012 I built a PC with the following spec:
    Motherboard - ASUS P7P55D Deluxe
    CPU - Intel i7 -860 2.8- GHz
    GPU - ASUS EAH5870/2DIS/1GD5 Voltage Tweak
    RAM - Corsair Dominator GT 8GB (4 x 2GB)
    O/S HDD - Corsair Force GT 240GB SSD
    Internal Storage - Samsung Spinpoint F1 1TB x 5
    PSU - Corsair HX10000W
    Case - Antec 1200
    It's been a while since I have looked at what the latest and greatest hardware is available, but am looking at upgrading.
    Not sure what I want to look at first, or what the best way to tackle this. I would most likely have to do this in stages.
    Any advice appreciated.
    Thanks
  2. murraynt
    murraynt Well-Known Member
    6 Jun 2009
    What do you use your PC for? Have you it over clocked?
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    The base platform is really still pretty capable. If you're finding you need some more CPU power, you should be able to OC that chip +1gHz at least with little effort. It really depends what you use the PC for, but assuming gaming, I would just upgrade the GPU and hang on a little while more for Skylake. The only other things I would do personally, is drop all those 1TB disks and replace them with 4TB or 5TB disk and do a case refresh (unless you may be wanting to downsize to matx or itx next time).
  4. TheMadDutchDude
    23 Aug 2013
    That system is still more than capable on the CPU front. You can easily overclock it to 4GHz which will bring a new lease of life into your (assuming) gaming experience. If you need help with overclocking, there are plenty of guides around, and of course you have the forums to ask for advice too. I'd be happy to assist if you shoot me a PM, if you need any help that is.
    Where the build is now letting you down is the graphics side of things. Make a switch to something new, and you will be surprised how well it copes.
    I personally wouldn't bother changing the HDDs unless you're running out of space or are planning to downsize as said above.
  5. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    Use it for gaming, nothing serious, but noticing more games needing a minimum of 1GB of graphics, recommended 2GB, which got me thinking about general upgrading. I haven't overclocked yet, so that could be a choice.
  6. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    Thanks for the advice. Will look into overclocking, and appreciate the offer.
    Graphics does seem the area I need to look into. Any suggestions? Also what's regarded as a decent size of card?
    Regarding the HDD's use them as a means to store and also backup all our data, and photos. We run a couple of businesses from home, and our previous NAS went wrong, so until we get another one, we have a setup using these hard drives for that. Have the same setup on another PC as well, so we always have four current up to date copies of all files. Plus offsite and also relevant data stored in the 'Cloud'. Sorry gone off on a tangent there.
    Back to the upgrade. Any thoughts on the RAM?
    Cheers
  7. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    Thanks for the message. Overclocking and GPU seem a common area to look at. Please see the comments re the HDD's. I know your comments, were your personal view, and can understand that, but for what we need at the moment, works well.
    Thanks again
  8. silk186
    silk186 Derp
    1 Dec 2014
    You could upgrade the RAM if you wanted as DDR3 will increase in price as DDR4 decreases but you really only need to upgrade your GPU.
  9. TheMadDutchDude
    23 Aug 2013
    I don't think more RAM is of much use at the minute. 8GB is enough for gaming. The only downside to his rig now is the graphics in my opinion.
  10. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    Any suggestions on a decent, but not too pricey graphics card? Always been pleased with my ASUS.
  11. TheMadDutchDude
    23 Aug 2013
    What sort of budget are you working towards?
    If you're willing to go second hand, you will get a lot more for your money. I picked up an ASUS DirectCU II R9 280X from here for £90 (complete bargain and a steal at that price) last week.
    I've also got two GIGABYTE HD 7970 GHz Editions here which I will be listing this weekend. I'm unsure of the price as of yet, but I will be putting them up. One needs to go back to GIGABYTE for repair work on the fans though. So that one is on hold for obvious reasons.
  12. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    To be honest, not really thought of any budget yet. I guess as I have a working system, I am in no immediate hurry, so if something is more expensive, I will save to get it. If that makes sense? Of course would like to spend as little as I can, but on the other hand, want something that will last. Putting my finger in the air, I would say up to £200 would be a good place to start. That said, if someone recommended a excellent card for £250, I would most likely save for it.
    What is the usual 'recommended' size these days? I know when I got my 1GB a few years back it was regarding as more than large enough for it's time. Don't think that's the case now :eek:)
  13. IvanIvanovich
    31 Aug 2008
    I wouldn't suggest any card with less than 3GB of vram. I recommend what I have, an evga gtx970 ssc acx2.0+. It's a really nice card if you want to go for nvidia.
  14. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Personally i would wait until AMD's 390x price/performance is known (supposedly) next month, if not i would go with IvanIvanovich's recommendation of a gtx970.
