Modding Tin Foil Pc
Discussion in 'Modding' started by Guest-23315, 7 Jul 2008.
  1. Guest-23315
    Guest-23315 Guest
    Firstly, I know its actually aluminium foil, but tin sounds cooler..
    My PC has been giving our houses digital some headaches, such as no reception what so ever when my PC is on. So instead of buying a new case sans-windows, I raided the larder.
    The results:
    I know, its pretty leen. I found an old, longer power switch and extended it out of the case, covered the windowd panel, and the drive bays, while leaving the front 'slots' open to feed my radiator. Just check the DVD drive hole. You don't get that sort of quality on a Lian-Li :p
  2. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    Cool - no sorry, not cool!
    Have you tried just putting it in another room?
  3. Guest-23315
    Guest-23315 Guest
    Its my PC, so it has to be in my room. I really don't care about the looks, aslong as it serves its purpose.
  4. lost_modder
    lost_modder What's a Dremel?
    5 Dec 2006
    Any idea where the signals are comming from? Cheap powersupply/modded powersupply/cooling pump? Something is causing the trouble, find it and kill it.
  5. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    woah dude, what kinda problems you having that makes you do that!?
    that's one uber cool mod! i love the way you show the hard effort and work by leaving the sellotape on visible. it shows grit and craftsmanship! hehe.
    ranks up among the duct tape mod for cheapness :D
  6. GavX
    GavX What's a Dremel?
    5 Apr 2008
    ghetto-tastic :D
  7. wolfticket
    19 Apr 2008
    Serious mental illness?
    Satellites are reading my computer's mind! :D
  8. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    That is pro! you gotta do what you gotta do...
  9. GavX
    5 Apr 2008
    Have you thought about using spray paints with flakes of metal, might stop some interference, not that there is anything wrong with it the now :D but on a serious note, if somethings stopping your PC signal, thats bad as the only things I know I have that do that are hairdryers (my sisters, not mine!) and the hoover
  10. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Manks how about you use double sided sticky tape and line the INSIDE of you case with foil. Same effect, better looks. :D
    Anyway nice ghetto mod. :thumb:
  11. Matticus
    Matticus ...
    23 Feb 2008
    Mankz this has to be your best work yet. If only you had put this much care and attention into watery :nono:
    But really couldn't you just shield the case from the inside out. Or make a mod out of it, maybe sandwich some tin foil in between perspex, if it was possible to get it remotely flat.
  12. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    love it, is this a temporary fix?
  13. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    leave . now . and . never . come . back
  14. kenco_uk
    28 Nov 2003
    You're right, there.
  15. Guest-23315
    Guest-23315 Guest
    For the summer, yes :thumb:
  16. Cheapskate
    13 May 2007
    :hehe:
    I thought you were in China, trolling for the gold. Why are you already back at your old hunting ground?
  17. Xer0-
    Xer0- Waste of space
    26 Mar 2007
  18. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    TYHEyre CoMiNg To GeT Me!!
    that is weird to do man, maybe for more DIY ghetto looks you could duct tape over the foil!
  19. Langer
    Langer Jesse Lang
    24 Jan 2004
    The lack of damage to the floor layer in that photo makes me think PRANK more than anything
  20. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    lol cool office prank :hehe:
    As for the reception problem, how about improoving the shielding & reception signal of your house's digital, instead of uglyfying your pc? There must be other devices in the house that also interfere such as hairdryers, vaccum cleaners, etc, no point wrapping everything in the house in tin foil, or the place is gonna end up looking like that office cubicle :hehe:
