Well I own a Lian Li PC-61 case. In the back I have 1 80mm fan for exaust and one for PSU (Enermax). Inside i have a modded card cooler its a big 120mm Delta Fan it doesn't take up any PCI slots but it sucks air away from my GF 4 TI 4600 cause the air from my G card is blowing directly on my sound card. I also have two front intake fans. In the back there are like 4 openings pretty small i would say about 2in maybe 1.5in anyway does anyone know where i can get fans that small. I could use some extra exhaust. Thanks.
try nexfan.com they have fans as small as 40mm, and they're relatively cheap too.... for 1.5-2inches... its gotta be either a 40mm or a 50mm spot... if you measure it up exactly, you're likely to find some there
I noticed Macroman has done this on his mod at article 35 looks good, i've done the twin outakes but haven't gotten round to the smaller ones.
Hey, not to hijack this thread, but: http://www.nexfan.com/43/357.htm Wow, a clear YS tech 80mm fan for six bux!
yeah... they're great....... but shhhh you might wreck my secret (hint.. try bg micro for 12v dc fans... and look at what they are)
Are those dual 80mm fans on the back of his case? If they are i might just do that. Thanks. P.S. I am getting 4 of those YS tech clear fans. Just in case Edit: Well i measured the holes on back they are exactly 1.5in. Hopefully Delta makes a fan taht would fit there!!!
Yeh, they are dual 80mm, its a squeeze though so carefull when cutting I know OCS has some 40mm fans (1.5") but have known some to whine in the past so am a bit dubious about using them, i'm not after more whine, hole point of watercooling is to remove all the noise, and boy, that works well, use a baybus to turn all the fans down to a mere gentle rythmic hum. Love it.
A word of warning about small fans - the pitch of the noise they generate is just about the most annoying known to civilisation! Seriously - I had 2 Coolermaster Cooldrives with tiny 40mm fans in the front and was soooooo relieved when I sold them.
Thats what i was afraid of, shame they dont state pitch levels on the spec of fans as many a time in the past bought a hs fan combo and its screamed like a banshee at me. If anyone knows any "quiet" 40mm fans (Thats if they exist at all) then can ya let us know what they are? Thanks
