Scratch Build – In Progress Tiny HTPC (semi) passive, Full HD, 1080p bluray(really finished+lil report 28/6)
Discussion in 'Project Logs' started by ichessblumen, 8 Apr 2008.
  1. brinkz0r
    brinkz0r What's a Dremel?
    15 Dec 2006
    That looks stock, great execution!
  2. Attila
    Attila still thinking....
    22 Feb 2008
    If this wasn't a family oriented site I could tell you
    what that case just did to me.
    Absolutely gorgeous!
  3. Kenny_McCormick
    Kenny_McCormick Minimodder
    19 Sep 2006
    I love this case... It seems to be just bought from your local store but it's home made. Congratulations!
  4. airchie
    airchie What's a Dremel?
    22 Mar 2005
    That's some awesome work!
    I think the best way to describe it is 'sexual chocolate'.
    I only skimmed the thread and looked at the pics so I apologise if this has been discussed.
    How is the cooling from the heatpipes and stuff?
    Does it play HD movies smoothly etc?
    Is there a remote?
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    class!
    The _only_ thing i could comment on is the fact that the VFD and the DVD tray aren't aligned. I'm a fool for geometric correctness, and this build is otherwise so precise, that it jumped to my eye. The fact that the rest is perfect enough for me to notice is a compliment in itself i guess :)
  6. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Very cool man, great work there! It looks flawless from the outside. I really like the clean, classy look too, this case gets two thumbs up from me! :clap:
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    wow, that looks really nice. great execution.
    any chance of a detailed guide / more pictures on how you made that heatsink?
  8. ichessblumen
    ichessblumen What's a Dremel?
    8 Apr 2008
    Thank you all for your very nice comments on this worklog. I haven't reckoned that there'd be so much attention. Thanks again.
    There arose some questions I try to answer.
    I fiddled around abit with a software that came with the board. It's Gigabytes "EasyTune5" which should allow a fine adjustment of the cooler. Until now I was'nt able to set the right values that it works as intended.
    At present it runs continuously. It's not a disturbing noise. Would say...noiseless.
    But that was not my intention. I'll try some other adjustments to get it to work....
    The cooling works. I felt the fins heaten up during workload as I've playbacked a blu ray( "AC/DC live at donington", the first Br I ever bought). No stuttering or any other negative side effects happend.
    The temp monitor shows continuously 55°C for the cpu at 41% max load... But as always you can never trust this software meter.Neither TAT, Everest home nor other. As long as it works...never mind.
    Yes, there is a remote came with the vfd. It's a MPLAY blast 202 from http://www.vlsys.co.kr/English/retail_blast.php. It works out of the box with M$ mediacenter.So it shall work with mediaportal as well. We'll see.
    hmm, sry..no. There aren't more pictures. But I can describe how I fabricated this heatsink.
    First thing ist to find a block ofy alloy or copper where you can take in the heatpipes.
    Make a layout/plan and screw the block onto the motherboard.
    Use instead of the heatpipes some fitting cables as a dummy to find out the needed length of the pipes and order accordingly.
    Measure the distance between the heatpipes holes on the cpu block and drill the holes accordingly in the fins. I used a 6.0 mm drill. Try different drills on a dummy beforehand to make sure they will fit.
    Cool down the heatpipe with some cooling spray that the will shrink abit and accordingly heaten the fins that they will widen abit and take the heatpipes in.
    For the bending of the heatpipes I used a bending spring ( see page 3, noxx asked).
    Then you can mount it in the block and adjust depending on your wished rig.
    Next time I will fabricate the block also by myself. I'll use two copper plates and put a 0.3mm alloy sheet in between. That makes shure that the pipes will fit nicely and theres no fiddling around with cooling spray and heating up the copper.
    That's it so far.
    Thanks again for the nice words. On Wekend I'll come up with a small update and report on the Mediaportal software installation.
  9. Dira
    Dira What's a Dremel?
    1 Sep 2005
    Very nice! Only one thing I see as a potential problem. Dust :S Are the sides open? Could fill up with lots of dust witch isnt helping cooling :p
  10. nickhelton
    nickhelton What's a Dremel?
    13 Feb 2008
    thanks for the explanation :D
  11. ichessblumen
    8 Apr 2008
    thank you...
    yes, this has been dicussed before. but i'll blow some compressed air inside from time to time. since the sides are open it'll come out easyly.
  12. broots
    broots What's a Dremel?
    24 Sep 2003
    I can only add to the list of positive feedback - Congratulations on a superb piece of craftmanship. Clean, subtle and classy!
    May I ask where you found that VL systems display?
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    fantastic!
  14. Dira
    1 Sep 2005
    Ok ty for answearing :) I do the same with my system ::lol: Gratz on an imba system!
  15. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    no words are necessary, just: :clap::thumb::jawdrop::jawdrop::thumb:
  16. wiak
    wiak What's a Dremel?
    9 Apr 2006
    tiny?
    mine can be called tiny
    http://picasaweb.google.com/tommarnk/GigabyteGAMA78GMS2H/
    Specs:
    Athlon 64 X2 5000 Black Edition (cool"n"quiet Enabled) 30c
    Gigabyte GA-MA78GM-S2H
    OCZ Gold XTC 2GB Dual Channel
    Samsung T166 500GB
    Hiper Media Series Black with 200W PSU
    D-Link DWA-140 Wireless 802.11n USB Stick
  17. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    hey tommy why don't you build your own custom case and create your own thread.
  18. ModimusPrime
    ModimusPrime The Dremelator
    3 Jan 2008
    Turned out awesome! Truely a great case with a classy minimalistic look, well done mate.
    @ wiak - Don't insult the modder with a thread highjack, especially after a brialiant project log. As Tec said, if your eager to show others your mod than by all means please start a thread.
  19. wiak
    9 Apr 2006
    i didnt mean to insult
    his mod is a good one :thumb:
    the custom cooling cpu alot better :brrr:
  20. misterkholl
    misterkholl modMode:on
    18 Jun 2006
    Beautiful!!! total quality!!! :thumb:
