tiny little motherboards? for tiny little cube mod
Discussion in 'Hardware' started by phaSe, 8 Jul 2002.
  1. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    hi guys,
    im trying to build a little plex-cube case, but dont know what sort of motherboard to use. im only going to use the onboard stuff and it would only need 1 pci slot ut im not sure which one or where to get them in the UK. any help would be rally appreciated :D and of course ill post pics when its done......
  2. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    How Tiny?
    There is the Eden, the Shuttle boards, and I think Asus makes a small board, but it isn't all that small.
  3. Guest-16
    Guest-16 Guest
    www.bindibadgi.co.uk/NA/MOBOS.xls
    tis about 3-4 months out of date now, but its a starting point! Also its Skt 370 only, they do do mATX/ FlexATX p4 and Tbird mobos too.
  4. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Or you could got for the uber biscuit board type of stuff.
  5. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    eden platform will probably be ideal...:idea:
  6. phaSe
    4 Jul 2002
    thanks for the replies guys!
    ive been looking at microATX but they are toooo big! ive seen the eden platform microITX but the processors dont seem meaty enough! i still want to be able to play games just not necessarily at 1600x1200 with all the bells and whistles!
    does anyone one know if ITX or microITX will take ether t-birds or socket 370?
    bindi - thanks for the xls, its a good starting point! i assume 'f or m' means flex or micro?
    kevo - whats busuit board? it sounds tasty and anthing thats uber is good in my books! :hehe:
  7. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    I think eden is the only ITX mobo out ther as of now...and small + performance dont go hand in hand...your best bet is a mAtx socket 478 with a AGP slot...sigh....
  8. Kevo
    9 Sep 2001
    This is a b board...
    Its only 5.25" across.
    Heres the specs:
    Supports Tualatin Cores up to 1.3GHz Socket 370
    RS-232 x 3 + RS-232/422/485 x 1
    2 x IDE Channels
    LAN 100/10M Optional 2nd LAN
    USB and IrDA
    Savage4 3D/2D LVDS/TFT/DSTN
    Optional TV out
    PC/104 Connector and PCI Slot
    Audio onboard
    CompactFlash-I /II Socket
    But because its a very specialized product you will be looking at £500-600 for it. :eeek:
    Several types of these boards can be found at http://www.milesie.co.uk/ cheaper ones too!! ;)
  9. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    That board has an ungodly amount of connectors!? Are the LPT/COM/VGA ports accessible like the old AT ones or something?
  10. Kevo
    9 Sep 2001
    Kind of ;)
  11. phaSe
    4 Jul 2002
    thanks for the replies.
    that biscuit board stuff looks wkd but a bit tooo ££££ maybe someday tho..... i think it will have to be one of the shuttle boards, probably a sv25 for some P111 lovin'! now all i need to do is find a plastic bender....;)
  12. Guest-16
    Guest-16 Guest
    i tihnk asus did a p4 flex atx sis based board, unless you want itx teeny size.
  13. Fronzel
    9 Mar 2002
    I saw Shuttle is working on an Athlon based board with an AGP slot for their SS line of mini computers.
    That would make it a great system for LAN parties. As opposed to now, where they are good as LAN party servers. Up to a point.
    That would be the bees knees.
  14. phaSe
    4 Jul 2002
    hmmmm agp would be nice, but im trying to start ery soon so its gotta be a dinky shuttle one! thanks for the help guys, ill post pix when its done!
