Cooling tiny pump needed
Discussion in 'Hardware' started by Boswell, 20 Dec 2005.
  1. Boswell
    Boswell Minimodder
    23 May 2005
    i want my watercooling to have a very impressive shower effect on the front of the res. but my current pump doesn't quite push the water out as much as i hope so is there a tiny pump (only needed for this shower effect) that uses the computers power and capable of having 1/8" - aqua computer tubes being put through?
    Thanks for in advance
    Ed
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    DDC if you want Power.
    CSP-MAG if you want uber small!
    Both would do it ;)
  3. woodshop
    woodshop UnSeenly
    14 Oct 2003
    windshield wiper pump maye do the job. they are 12V and probably have 1/8 fittings. although not sure on fitting size probably different for every make/model
  4. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    one problem... windshield viper pumps arent made for long term runs -> will die fast
  5. Boswell
    Boswell Minimodder
    23 May 2005
  6. Shadowed_fury
    21 Nov 2003
    Its usually around that price yeah ;)
  7. Firehed
    15 Feb 2004
    Umm... going by the vague description, I think you just need to pick up an aquajet.
  8. Boswell
    Boswell Minimodder
    23 May 2005
    yer i have a aquajet but i have used a small pump in the past but it needed mains power (+ with my eheim 1048 needing mains power at lans its more of a hassle to get 2 extra power slots... which is why i needed computer powered one), and it (the small pump) provided a better looked - much more powerful effect than just if i ran the single eheim.
  9. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    i think a mag has been proven more powerfull than a 1048, so if u got two and used them in parallel you should get the waterfall affect out the aquajet that you desire, plus both the pumps would be 12v <- that come with a 3pin fan connection and could be run off a fan header, or your aquero for that matter (and not to mention mags are only 2" square saves space in the case), no need for a extra plug, and u get better flow all round :D
    seems like a win win situation :thumb:
  10. Nexxo
    23 Oct 2001
    The CSP-MAG has unresolved leakage issues (extensively explored on ProCooling forums) and the current opinion amongst watercooling geeks is to avoid it, and choose the Laing DCC instead.
  11. sc4mpi
    16 Jan 2005
    had a look at the post the other day on procooling, thought they were ment to have improved the problem over the csp mk II, guess not :(
  12. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Yout got to be kidding me, back when I was asking if it was a good pump everyone said it was sweet and there wernt any problems with them! So I bought it a month ago but havent been able to test it yet. They Leak!!!??!!!! Now im scared to put it in my new rig. *pokes it with a stick* All the specs I can find on it say its leak proof due to not a shaft seal. Now Im scared to put this in with my $1500 worth of shiny new pc parts.
  13. specofdust
    specofdust Banned
    26 Feb 2005
    Listen to this man regarding water cooling. He R the god of water :thumb:
  14. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    The CSP-MAG also has issues of rust... see here.
    Laing DDC/ D5 is the way to go ;)
  15. Boswell
    Boswell Minimodder
    23 May 2005
    hmm i have heard that the laing is very loud though...is this true?
  16. Shadowed_fury
    21 Nov 2003
    The DDC isn't, I can tell you that! :D
  17. Boswell
    Boswell Minimodder
    23 May 2005
    ok sounds good so far... is it 3 pin or 4 pin?
  18. Nexxo
    23 Oct 2001
    Does it matter? Are you a modder or a mouse? :p
    You have to understand that PC watercooling is a constantly evolving field. New stuff comes out, improvements are made (or at least, attempted). New stuff is tried and tested, and experience of long-term reliability is gained only in the long term. As such our knowledge base constantly evolves and updates as well. This is why you should always stay updated and never get complacent, and be prepared to experiment a bit.
    If it is any consolation, I made several changes to my setup while I was building it, including the pump (from a Johnson CM30P7-1 to a Davies-Craig EBP).
  19. Boswell
    Boswell Minimodder
    23 May 2005
    good point :)
  20. sc4mpi
    16 Jan 2005
