PSU Tips on quieting the PSU? (except cleaning, replacing fan or getting a new PSU)
Discussion in 'Hardware' started by oscy, 20 Jan 2020.
  1. oscy
    oscy Well-Known Member
    22 Sep 2011
    I read a guy turn his the other way round so it was sucking air from the inside and getting a huge noise difference, so wondering if there's any other random tricks before I try.
  2. Big Elf
    23 Apr 2009
    Put a resister in the cable.
    Replace the fan with a quieter one.
    I've done both and as long as it's a decent PSU you should get away with a slower, quieter fan. No guarantees though.
    9 years ago I bought a Seasonic P1000 and have used it for for 99% of the time with the fan permanently switched off in my PC in my sig. It cost a small fortune at the time but quality counts.
  3. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    I'd say the list of what we cannot do are your best options. Clean is your best option if the fan has changed the noise profile, new fan for best performance, new PSU if you want no fan. Otherwise your other option is to divert the noise, without overheating your PSU. Flipping the fan is one option if it doesn't mess up your case air flow, which is true in most modern cases. A decade ago maybe more people messed around with PSU mufflers, foam lined boxes to absorb the fan noise. This fell out of favor as new fans achieve higher results with out comprising air flow.
    Edit:
    Wait I forgot one... custom water cooling the PSU. I do not recommend this in any way.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    If you're going to take it apart to clean it or change the fan don't go poking around with anything conductive like a screwdriver or your fingers though, don't want you dying on us. :)
  5. spolsh
    spolsh Active Member
    4 Feb 2012
    And FSP do a PSU with a water block on it ... just made me laugh.
  6. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    Pretty much.
    I'm assuming this is the fan noise you're talking about, in which case turning it round so the fan faces in may help as the noise is directed inwards more and has to bounce around to get out.
    A bit of foam or rubber underneath to dampen vibrations is an option.
