Blogs Titan Fenrir Evo Hands-on
Discussion in 'Article Discussion' started by Sifter3000, 17 May 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    I like the black/gold colour scheme, just wish they had kept to more black that gold though. It makes it look too blingtastic!
  3. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    do. want. when will BT/CPC get one to test?
  4. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I might just take the plunge although it seems a bit futile considering I already have a decent cooler.
  5. capnPedro
    11 Apr 2007
    Titan need to get it over with and just do a range of different coloured models so everyone can get the colour that matches their PC's colour scheme.
  6. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    NICE!
  7. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    Looks like a Scythe Gentle Typhoon but with more bling.
  8. Baz
    Baz I work for Corsair
    13 Jan 2005
    Does look very similar doesn't it? Be sure we'll get one for testing ASAP.
  9. barndoor101
    25 Oct 2009
    let us know if its worth upgrading the fan if you already own a first gen fenrir.
  10. shadow19935
    shadow19935 Whats overclocking? :D
    17 May 2010
    Dont really like the look of it, maybe performance will make up for it?
  11. Lockon Stratos
    Lockon Stratos I Will Snipe You!
    19 Apr 2010
    It is defnitely not - read the article again. Titan have already said that its the same cooler as the previous with the only 'REAL' difference being the fan. just buy a Scythe Gentle Typhoon 120mm fan. It doesnt come in the same gold colour or have PWM function but it looks just like the one titan are using. I am hugely dissapointed in Titan. there is no reason for this new product to exist. but its there because Titan are trying to milk their product. what an utter waste of time n effort.
  12. barndoor101
    25 Oct 2009
    i realise that the fan is the only change, however if it is significantly better than the one that comes with fenrirs at the moment then it may be worth a punt - meaning i will buy the fan on its own:
    Titan will launch the fan by itself in a retail package
  13. ripmax
    ripmax Minimodder
    8 Apr 2010
    Yeah, the only reason you would buy one of the special editions is if you don't already have a Titan fenrir.
  14. wyx087
    15 Aug 2007
    just release 1 version and that's it, no need to re-release so many. at most, release in revisions so it's easier to distinguish between which one's the latest. (eg. TRUE revC)
  15. Lockon Stratos
    19 Apr 2010
    & the sky is blue.
  16. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Could you not just buy a better fan to replace the old one anyway instead of waiting for the Titan one?
  17. Lockon Stratos
    19 Apr 2010
    of course you could. theres nothing stopping you. you dont need to use the fan thats bundled with the cooler. put your own one on
    Guest-16 likes this.
  18. barndoor101
    25 Oct 2009
    most case fans dont have PWM, and also their CFM and static air pressure is quite weak. one of the reasons the fenrir does so well is that the fan can ramp up to a huge CFM but is very noisy. if this new fan can do a similar CFM and static air pressure but quieter then its worth an upgrade.
  19. Lockon Stratos
    19 Apr 2010
    Akasa apache is a good fan to stick on a cooler - its dead silent, moves a decent amount of air, has PWM & also comes in 2 colours. but if your looking for LED bling then your gonna have to look else where,
  20. capnPedro
    11 Apr 2007
    I call shenanigans!
    Nothing made by Akasa can come close to being called silent when compared to Gintle typhoons/Silent Eagles/Noctuas.
    (I'm ignoring the fact 'silent' should really mean 0dB because everyone uses it to mean 'quiet' but it annoys me)
Tags: Add Tags
