Cooling Titan Fenrir
Discussion in 'Hardware' started by leebarros, 30 Dec 2009.
  1. leebarros
    leebarros What's a Dremel?
    2 Jun 2009
    I got my Titan Fenrir today from ebay (used but in very good condition) I have all of the following parts in the picture below except the bracket in the middle which I believe is needed for an LGA775 setup.
    Can anyone confirm this?
    Cheers,
    -Lee
  2. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    If its the item I have circled in red then yes it is indeed needed for LGA775 as its the main back plate and it helps distribute the weight of the cooler.
    If its the item I have circled in yellow then that is for an LGA 1366 setup and wouldn't be needed if you have an LGA775 setup.
  4. TheBlackSwordsMan
    16 Aug 2009
  5. leebarros
    2 Jun 2009
    In the auction, the seller stated that he had all the fittings for LGA775 and that he had tested it on this platform, however I dont seem to have the part that you circled in red... I have contacted the seller about this and hopefully I get a reply...
  6. daisy542
    daisy542 What's a Dremel?
    31 Dec 2009
    Hmmm not sure I was surprised I got it to work because I usually can't get things like this to work. Maybe try resizing before you try to upload IDK
    ________________________
    Koozies| Custom koozies
  7. leebarros
    2 Jun 2009
    Im not sure what you mean? lol :eyebrow:
  8. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    He means "I am teh spambotz lololololol".
    Did you hear back from the eBay seller?
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    not too sure, but you could use one of these to mount it.
  10. TheBlackSwordsMan
    16 Aug 2009
    I think we can say, any 775 backplate can be use. no ?
  11. MaverickWill
    26 Apr 2009
    Yeah, any 775 backplate can be used, but the OP was told the Fenrir was tested on a 775 socket and had all fittings, so he should have one anyway. Some eBay sellers are rotten, tbf.
  12. TheBlackSwordsMan
    16 Aug 2009
    Or Just cut a metal square, take mesure and make hole.
    Look this home made backplate
  13. leebarros
    2 Jun 2009
    Still no word back from the seller - He has included the LGA1366 fixture but not the LGA775 - didnt know that you could buy them though so may take a look into getting one this week from somewhere.
    Once I get one, its down to giving the system a good clean (Dust filters are doing a magic job - only thing is they get filled up quickly!) then installing the new Titan Fenrir!
    Cheers :thumb:
