Hi All! Now im modding my TJ11B-W, prepare it for watercooling stuff and better cable management. Hardware was: CPU: i5 3570k MB: Asus z77 Sabertooth RAM: Corsair Vengeance 1600C9 LP 4x4Gb GPU: NOw i have only 660GTX 2Gb and i really want to change it. SSD: Kingston V200+ 60Gb HDD: WD Caviar Blue 1Tb x2 PSU: OCZ Modxstream 700w CF: Scythe Glide Stream PWM 1300rpm
I don't have much time for this, so only part of update - the grills, screws and test fans I will add photo later, now LQ video: http://www.youtube.com/watch?v=KAeBaoEIG2U&feature=youtu.be + window mod photo, you can see grill's material, it's the same: btw thanks Hukkel!
Hmm... interested in the button splitter! What will they be doing? Looking good so far, excited to see more! -Jeffinslaw
Okay, a little brake over xD Will do a new one, for 16mm buttons and MORE black O-Ring testing And sleeving... Also got this baby: And decided to go with single rad. So 560 rad holder will be done soon.
Rad holder and control panel are done. I don't have photo of rad holder, nothing special there. Also add bottom lightning (able to switch on/off in final build)
Well it's still alive, still unfinished and it's totally reworked now. It has a new 560rad+D5 pump+aquaero 5lt mount system on rigid tube: Some plastic decorative parts on front panel: And modified monoblock, clean and shiny: Also since year 2015 some parts was added: Second D5 Pump 360x60 Radiator Double reservoir Custom cables Custom case parts Now i'm waiting for some parts to finist some steps. Now it's looks like:
Sometimes we need to wait M2 SSD with no wires to make a clean build. Upper bay tubes in progress Now tubes go lower and i can install really long VGA, maybe up to 34cm. Next step - a custom bracket for 360mm radiator, not for 240mm like now from previous version of this build. D5 pump will go lower and i will try to replace res tube for 200mm or something. And replace all fans xD Because even both of new CM 360 masterfan has damaged/noisy bearing. Bottom 140 fans are just old, they was installed 5 years ago and i will replace it for Arctic P14. Custom case parts allows me to do it really easy. Because i have access to all fan screws
