Case Mod - In Progress TJ11B-WMod - UPD 15/03/2015
Discussion in 'Project Logs' started by Scare, 3 Aug 2014.
  1. Scare
    Scare New Member
    5 Jan 2014
    Hi All! :rock:
    Now im modding my TJ11B-W, prepare it for watercooling stuff and better cable management.
    I hope to finish this stage at oct/nov 2014. (custom parts, 560x60 and 360<45mm rads installed)
    Main colours is black aluminium/powder coated steel and stainless steel, cold white lightning.
    Some kind of black sleeve/hard tubing later :worried:
    I call it "Anniversary Edition"
    Hardware
    CPU: i5 3570k
    MB: Asus z77 Sabertooth
    RAM: Corsair Vengeance 1600C9 LP 4x4Gb
    GPU: NOw i have only 660GTX 2Gb and i really want to change it.
    SSD: Kingston V200+ 60Gb
    HDD: WD Caviar Blue 1Tb x2
    PSU: OCZ Modxstream 700w
    CF: Scythe Glide Stream PWM 1300rpm
    So it will be a few "mod packs"
    :idea:
    1. Midplates
    2. Mount Stuff
    3. Top Mod
    4. Other
    1st - Midplates!
    1st of all - midplates!
    The only thing which will help me improve cable management and allow to install 360rad with good aesthetics.
    1.1 - Vertical inside midpalte [VI]
    The Grills - 1.5mm stainless steel and polishing.
    1.2 - Horisontal inside midplate [HI]
    This will be a mount system for 360rad and help me to get a better cable management.
    Preview:
    2nd - Mount Stuff
    Really need to do this to get enought free space for aesthetics and watercool.
    Also i will get a custom rad holders/shround.
    Now only one thing is done - it's a HDD Cage/Mount :sigh:
    The design:
    And:
    It can hold 1x120mm fan and 3x5.25 HDD trays. It mounts in 5.25 bay of TJ11.
    3rd - Top Mod
    As you can see it will be an I/O panel LED light up (cold white).
    Sorry for LQ video and bad english :waah:
    http://www.youtube.com/watch?v=YKdqZR90izo
    And some kind of simple control panel for lightning:
    Already done steel panels, but still dont get good enough vandal buttons. :wallbash:
    4th - Other Mods
    Not so many to do here, just window mod and button replacement.
    And front panel wires cover, logo, etc:
    I will create some simple PCBs for control panel and better cable management inside 5.25 too.
    All hardware which you can see is my old hardware, i can resleeve PSU, replace MB/CPU or other things. Also i can change many till it's not ends. :confused:
    I hope all works fine, my first worklog on this forum.
    Next update - 2 grills and vertical midplate :lol:
  2. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I am ALWAYS ready for a TJ11 mod.
    Good luck!
  3. Scare
    Scare New Member
    5 Jan 2014
  4. Scare
    Scare New Member
    5 Jan 2014
    UPD 08/08/2014
    Some photos, not the best quality
    And a little bonus - working prototype of button splitter (for top control panel)
  5. Jeffinslaw
    Jeffinslaw Member
    26 Jun 2014
    Hmm... interested in the button splitter! What will they be doing?
    Looking good so far, excited to see more!
    -Jeffinslaw
  6. hero1
    hero1 Member
    18 Oct 2013
    This looks good. Subbed:thumb:
  7. Scare
    Scare New Member
    5 Jan 2014
    Splitter will do 3 things:
    1 - Main lights on/off
    2 - 2nd lights on/off (i wanna do 2 LED strips, maybe 2 different colours)
    3 - for I/O panel LEDs
  8. Scare
    Scare New Member
    5 Jan 2014
    Okay, a little brake over xD
    Will do a new one, for 16mm buttons and MORE black
    O-Ring testing
    And sleeving...
    Also got this baby:
    And decided to go with single rad. So 560 rad holder will be done soon.
  9. Scare
    Scare New Member
    5 Jan 2014
    Rad holder and control panel are done.
    I don't have photo of rad holder, nothing special there.
    Also add bottom lightning (able to switch on/off in final build)
  10. Scare
    Scare New Member
    5 Jan 2014
    Some electric stuff
    Grill
    I hope EK waterblock will fit on it
    EK everywhere
    Mounted a little bit wrong... will fix it
    2nd midplate incoming + reservoir mounts
    Also i'm searching about new grill designs (360mm stainless steel grill) and coolant type/color
    Any idea?
  11. Scare
    Scare New Member
    5 Jan 2014
  12. Scare
    Scare New Member
    5 Jan 2014
  13. Thorn
    Thorn Gaijin Studios
    19 Feb 2004
    good jobs
  14. Scare
    Scare New Member
    5 Jan 2014
    Re-worked a bit :duh:
    Only part of all stuff done now
    Don't ask why and don't see at wires and tubing.
    I will replace everything, also got some EK HD fittings and acrylic tubing.
    About coolant - probably it will be something from Mr. Bane
