Windows to get SP1 or not to get SP1. that is the question
Discussion in 'Software' started by Froggy, 21 Jul 2003.
  1. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    if it better to install sp1 or not to install sp1? i alredy patched the problem with the help and souport thing. i dont see any reasion to install sp1 becuase i have awalys noticed a performance hit after installing it. what has been your experiences with sp1
  2. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    Gaaah, I hate the bloody thing. my computer seems a lot slower upon installing (boot times are the most noticeable)
  3. Carbon
    Carbon Banned
    8 Jan 2003
    if i remember correctly when you install the updates for 2000/xp it installs some security update which for some reason :-\
  4. Nedsbeds
    16 May 2002
    I seem to remember something like that as well, funnily enough!! :D :D
    ......must resist urge not to reinstall xp
    what is this I hear about combining the install cd with sp1? is that a more stable solution?
  5. 554
    554 What's a Dremel?
    22 Jun 2003
    i think that was a prob with 1 update and firewall software
    i do believe that it has been patched now and shudnt affect the performance like it used to.
  6. Froggy
    10 Jun 2003
    i had it on the computer in my sig before last time i formated and i had a huge speed hit. no firewall at all. hmm why do i keep talking about my lack of securitys including a anti-virus the fact that i never ran windows update? anyway i noticed lower framerats and at least 30 more seconds in my boot time. BTW what are your peeps boot times? i havent tested my self in a while but after installing desktopx and many other things i noticed its going longer. anyway belive it or not i was able to get my old P3-600mhz 256 ram computer to boot in 29.88 seconds. last time i checked my computer in my sig booted in 12.21 seconds
  7. Carbon
    Carbon Banned
    8 Jan 2003
    how can you time how long it takes to boot? :confused:
    yes, using the integrated sp1 is better than installing the updates on a none sp1 xp IMO
  8. Nedsbeds
    16 May 2002
    after post is complete, mine boots in around 8 seconds!
  9. Froggy
    10 Jun 2003
    yea im trying to tweak it to get a faster boot time but im only down to 20 seconds. its beena while sence i formated so i got a lot of craplets on my computer. my fastist time was 12 seconds for my 2.8ghz machine. G5 the fastest personal computer my ass.
