Education Today I learned (TIL)........
Discussion in 'General' started by Kronos, 20 Jan 2018.
  1. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    You're not alone - I'm not a fan either. Unless I've been using it wrong, all beard oil does is make my beard feel oily for the rest of the day (I suppose the clue is in the name :winking:)
  2. Byron C
    Byron C Ripping a line of speed off a sh**-encrusted bog
    12 Apr 2002
    Beard oil is as much for your skin as it is for your hair.
    Do you get an itchy face when you have facial hair? Do you get dry skin when you have facial hair? Use a decent beard oil. You only need to apply it a couple of times a week and you really don't need much - most people only need a couple of drops. If it feels oily or greasy afterwards then you're using too much.
    Some people might not need it, that's fine. If I don't do anything then I get a lot of "beard dandruff" - beard oil clears it right up. I tend to keep it shorter these days, but when I let it grow out I used to use other products as well. My hair is wiry af, no matter how long I let grow it just grows out rather than down - whether it's regular hair or my beard. I'd look utterly ridiculous if I didn't look after it properly. Now I generally keep it short enough to avoid this problem.
  3. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Clove oil melts plastic....
    Couldn't find any ground clove at the shops, so decided to grind some I had at home.
    Loaded it in to my cheapy spice grinder that came with my mixer, ground up nicely and left the spice grinder on the side to wash up once I finished sieving it and doing some other bits.
    20 minutes later while washing the main body of the grinder smells like burning plastic and the inside is all pitted.
    Bugger, new spice grinder time. Probably glass this time.
  4. Mr_Mistoffelees
    26 Aug 2014
    TIL: Don't change a deleted thread title to "Ignore" or "Do Not Ignore", it's not worth it.
    Maybe try to find a less divisive middle ground option, like "Ignore or Don't Ignore, it's up to You."
    Pete J, adidan and Arboreal like this.
  5. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    TIL: Human hair can puncture skin. Just had to pull one of my beard hair out of my thumb. Stings like a paper cut.
    Mr_Mistoffelees likes this.
  6. Mr_Mistoffelees
    26 Aug 2014
    Today You Learnt: Don't sharpen the ends of beard hairs...
  7. adidan
    25 Mar 2009
    Yeah they can be nasty, some of mine are pretty much cat whiskers
  8. Ajbod
    Ajbod What's a Dremel?
    12 Dec 2016
    When i was young i had a Pilonidal sinus that was infected so became a Pilonidal cyst. VERY painful.
    It was incised 5 times, the wound packed with beeswax soaked sterile dressing, which was pulled out every day to drain more pus, then repacked. This was done for 5 days running each time.
    eventually it was excised under general anesthetic, with what i later discovered was an experimental dressing applied. it was sown onto the area.
    3 months later had Hepatitis. many years later told by a retired theatre sister of 40 years, oh that was a theatre infection.
    Nasty little buggers hair.
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    There are streets in Wincanton named after ones in Ankh-Morpork from Terry Pratchett's Discworld novels
    • Morpork Road
    • Hen & Chickens Field
    • Peach Pie Street
    • Treacle Mine Road (my favourite!)
    MadGinga, Byron C, IamJudd and 2 others like this.
  10. Byron C
    12 Apr 2002
    That's pretty awesome!
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Turns out Wincanton itself is officially twinned with Ankh-Morpork. :eeek:
    Byron C likes this.
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    TIL - Harry Ramsden (the chip shop founder) is Sooty the bear's great uncle
    Harry Corbett, creator of Sooty was Ramsden's nephew & used to play piano in the first restaurant at Guisley
  13. adidan
    25 Mar 2009
    TIL at 6:30am that the ifixit kit has the exact type of tweezers you need to remove a tick from the lower leg of your panicking OH.
    Interesting start to the day, no long walks through the tall grass in the woods for her until winter.
    IanW and Arboreal like this.
  14. Arboreal
    21 Jan 2011
    Hopefully it didn't require the ifixit explosions as seen on Jayztwocents YT ads!
    IanW and adidan like this.
  15. adidan
    25 Mar 2009
    Ha, no, I managed to save the leg :happy:
  16. Arboreal
    21 Jan 2011
    Good work Doc, Lymes is not something anyone wants
  17. adidan
    25 Mar 2009
    No, we'll be hawkish about it.
    Typical, the first tick a Finn gets is not in Finland but here.
  18. Mr_Mistoffelees
    26 Aug 2014
    Did you put it in the freezer?
  19. adidan
    25 Mar 2009
    Thanks for reminding me, I was overzealous, I best let her out :worried::happy:
    IanW, Mr_Mistoffelees and Arboreal like this.
  20. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    TIL - Kiss (the band) don't have makeup artists. They've always all done their own.
    adidan likes this.
