Motors Todays exploits......
Discussion in 'General' started by AW3K, 16 Oct 2003.
  1. AW3K
    AW3K What's a Dremel?
    3 Nov 2001
    i delocked my car today cos i was fed up of little s***s sticking screwdrivers either in the lock or under it. scum***
    Tell us what you think, before you say owt about filling it, i will when i get time but for now its plugging the hole :p Inox fixings lol.
    AW3K
  2. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    nice
    but wheres your sound dedening mate
    /me wander to his car with 10 rolls of dynamat i will make ti silent in there
    i cna picture somone comign to the car with a screwdriver to break in, goign to smash the lock & find it aint a lock
    hehe
    why not recess it a bit & then cover it in body filler, smooth ti down to the level of the metal & then spray it to colour match
  3. AW3K
    3 Nov 2001
    i can imadgain em trying it iching their head and just smashing the window lol
    I am gunna fill it when i get time to , also colour coding the handles and mirrors.
    AW3K
  4. crayfish
    crayfish Amazing scenes!
    3 Dec 2002
    How do you open your car :confused:
    [EDIT]
    Post number 100 :clap: :clap: :clap: w00t!
  5. SiMonTiST
    SiMonTiST Minimodder
    14 May 2002
    uh....
    IR/radio keyfob i'd imagine
    Also, TVRs have incredibly 1337 doors though - no handles or locks :D
  6. Shogun
    Shogun Banned
    18 Jul 2002
    what happens when the battery runs out on the fob? You are stuck thats what.... :lol:
  7. SiMonTiST
    14 May 2002
    always carry spare batteries
  8. AW3K
    3 Nov 2001
    LOL yeah its called a boot that still uses the key :p
    climb in and open the door :D
    yeah i could carry a spare battery, but i think it tells u when its running out or the led flashes or summet
    its a right diddy battery but its 12V !
    Yeah my alarm controls the locking and unlocking
    AW3K
  9. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    Some cars have an electric override switch for the de-locked doors under the sills or in the wheel arches (bad idea methinks) but you could put an override in the boot :D
  10. AW3K
    3 Nov 2001
    my idea would be flared cos the alarm would still sound :sigh: no way to over-ride it unless i had a battery for the fob in the boot, now theres an idea.
    an overide switch could be used yeah,
    i'll keep checking the battery every so often
    AW3K
  11. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    the alarm's not gonna go off if the battery's dead, is it? ;)
    nice one tho :)
  12. AW3K
    3 Nov 2001
    Transmitter as in keyfob battery will run out before the car battery cos i've just got a new vauxhall one for £25
    cheers :)
    AW3K
  13. crayfish
    3 Dec 2002
    I sat in one of those at last year's Motor Show in Birmingham. There's a button under each wing mirror, and two on the centre console. :cooldude:
  14. AW3K
    3 Nov 2001
    sweet could do that if i really wanted but i aint :(
    :sigh:
  15. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    you will know if the batteryis dieing becase it wont work at long ranges anymore. once i got mine in the remote starter so low that i had to pop the hood and stick the keys next to the reciever to start my truck. lol i looked like i was stealing the truck in the parking lot. :lol:
  16. AW3K
    3 Nov 2001
    A quick update LOL
    it would apper that sum numpty has tried to break in but failed lol
    the plate has been moved upwards and all the paint below it is chipped also there are streight scratches in the middle as if they tried a screwdriver,
    i'de av loved to seen their faces when they tried it
    AW3K
  17. Shogun
    Shogun Banned
    18 Jul 2002
    Is there THAT much car crime where you live AW3K? From what you describe it seems to be a massive problem.
  18. AW3K
    3 Nov 2001
    Acording to my local paper there is a gang going round doing all the pup and supermarket carparks in the area.
    since i work in a supermarket and my car is there every week , easy target!
    AW3K
  19. Shogun
    Shogun Banned
    18 Jul 2002
    surely they would think to install cctv or something. I wouldnt visit a supermarket if i knew my car had a large chance of being broken into.
  20. Froggy
    10 Jun 2003
    i wonder if they make car alarms that come with hydrolics so that your car would jump up and down while the alarm goes off. lol if that wont turn heads i dont think anything else will.
