Case Mod - In Progress Tom's Reject
Discussion in 'Project Logs' started by oggie, 13 Apr 2009.
  1. oggie
    oggie What's a Dremel?
    13 Apr 2009
    Hi peeps
    My first post on here so might as well start it off with a build :cooldude: Please go easy on this n00b :D
    This is my first build on here and my second build overall, so any advise/opinions/constructive criticism would be extremely welcomed ;)
    Quick pic of my current build before i get to my new one
    _______________________________________
    Well the reason i'm calling my build Tom's Reject is cause its the case i got of Tom (owner of ChilledPC ) which he didnt want any more :)
    Some pics of the case in current state
    As you can see it needs a bit of love but otherwise its in good condition :D
    Components
    i7 940
    Foxconn Bloodrage
    Corsair 6GB (3x2GB) DDR3 1600MHz XMS3 Dominator Memory
    4870x2
    850W Silverstone SST-DA850
    Watercooling
    Watercool HeatKiller CPU LGA1366 Rev. 3.0 LT
    Thermochill 120.3
    Black Ice GT Stealth 360
    2x Laing DDC 18w Pump (one with reservoir on top)
    XSPC Full Cover Razor HD 4870 X2 - Acetal (currently have this but want to upgrade to EATKILLER GPU-X² 4870X2 LT)
    EK Multioption RES 250 Rev2
    Bitspower fittings
    There are other bits and pieces i have got one the way such as Alphacool LCD, some OCZ Vertex SSD's, etc...
    My plans for the case are to have outside sprayed (black matt or gloss with red stripes and grills) and inside black satin powercoat. Top will be modified to hold 360 radiator, front will be modified so can have Lian Li bazel (to hide dvd drive) as it will also have window panel .
    Here is ruff sketch .....
    Some pics of goodies that have currently....
    As you can see there is gonna be a bit of red in my case so have decided to go with red braiding.......have not seen many peeps using this so might as well try it ;)
    Currently doing my SATA power cables and Molex ones :rolleyes:
    More to follow..........
  2. arkadur
    arkadur What's a Dremel?
    3 May 2005
    nice sleeving\wiring work
    look promising..
    good luck!
  3. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Wow! Good first post! This looks promising. Subscribed!
  4. Spoooon
    Spoooon What's a Dremel?
    19 Mar 2009
    That sleeving on the power supply looks sexy as!! :eek:
    good luck mate!
  5. Pieface
    Pieface Modder
    8 Mar 2009
    Love your choice of T-Shirt ;)
  6. oggie
    13 Apr 2009
    Been doing some more sleeving while watching footie today, not the best but will do as its bloody hard to do SATA power cables. My case is been done over next few weeks......gotta wait for it to be returned from powercoater and sprayer.....sooooooo bored at the moment
  7. wbdog206
    wbdog206 not me
    15 Jan 2007
    Very nice work.
    Can't wait to see more.
  8. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    Your current build looks great, its crazy how just a simple swap of the stock blue fans with orange can make all the difference.
  9. oggie
    13 Apr 2009
    Thank you, yeah was very happy for my first PC - looking to build something more clean
  10. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    looking great so far Oggie and Damnnice job on the sleeving looks amazing! any chance you could link me to it? just what I'm looking for
  11. oggie
    13 Apr 2009
    Got it from chilledpc, just ask Tom to order it for you....will be cheaper than getting it anywhere else :thumb:
  12. Editor22
    3 Jan 2009
    awesome! thanks alto dude :rock:
  13. oggie
    13 Apr 2009
    No problemo mate :thumb:
  14. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Gah, a Manchester United supporter. :p
    (The braiding looks great though)
  15. haakon.t
    haakon.t :)
    8 Dec 2007
    Manchester United-red, perfect choice :) Also awesome work on the sleeving itself!
  16. oggie
    13 Apr 2009
    Another bit done while waiting for my case....molex
  17. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    the wire management is siiiiiiick! :) props bro
  18. Editor22
    3 Jan 2009
    damn I'm dying for an update on this :eyebrow:
  19. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    sweet cable sleeving! :thumbs: Can't wait to see the case back from power coating.
  20. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    nice sleeving!!
