Windows Tony hawks ps 3
Discussion in 'Gaming' started by ToM, 1 Jun 2002.
  1. ToM
    ToM mmmm, blud
    14 Aug 2001
    ive just bought tony hawks pro sk8r 3, and i was playin it for a couple of hours, and i still cant figure out how to grind the molten bowl on the first level, its the only task left, and its really annoying me!!!
    and is there anyway to get huge combos on canada level, so i can get the sick 120,000 score?
    any tips mucho apreciated ;)
    cheers guys!
  2. vivid
    vivid down in fraggle rock
    24 Sep 2001
    when the molten bucket comes across and goes to tip all the molten stuff into the pit thing below you gotta grind the either side of it, use the ramp behind for speed and ollie up to it with the lip on the molten pit thing, hope that helps :dude:
  3. Hiren
    Hiren mind control Moderator
    15 May 2002
    Use a fastplant to get some speed as you come off the lip before you ollie. Also try: http://www.planettonyhawk.com if you get stuck anywhere in the game. I finally clocked the game this morning! Only another 13 charectors to go.
  4. RTT
    RTT #parp
    12 Mar 2001
    when you start there is a rail and and a fence.
    ollie onto the rail and grind it
    then ollie 180 from the rail onto the fence (to the right) - when on the fence grind it and perhaps ollie (or ollie 180) a couple of times (to multiply score)
    then you should be nearing a box type thing towards the end of the fence which is to your left. ollie or ollie 180 onto the box, grind the box and then as you come off the end of the box 360 ollie and land :D
    should get you about 30,000 points when you land...
    then you approach a ramp thing, do a trick off the ramp and come straight back towards the box, fence and rail and keep doing the same combo - I got 400,000 odd points doing that for the 2 min time period :D
  5. buglish
    buglish What's a Dremel?
    8 May 2002
    that games too easy, i rented it on the gamecube for 2 days and completed it with 5 characters:lol:
    what are every1's top combo scores? i got 2.2million on airport w/o cheats
  6. GiGo
    GiGo was once a nerd.....
    12 May 2002
    I like the game, it is veru easy. Completed the whole lot within a week. All I need to know is how to revert! Please tell me how to revert for the PC.
    Once I know the revert 10mill + combos coming up
  7. vivid
    24 Sep 2001
    its numpad 7 methonks, check your key setup at it shud tell you
  8. Elemental
    Elemental What's a Dremel?
    28 Dec 2001
    If the game's too easy for ya, try playing with keyboard, like me :rolleyes:
    Never got more than 20.000 for a combo :cries:
  9. GiGo
    12 May 2002
    I do use the keyboard, it is the best controller in the world. You have got more than 20.00 combo. did you have THPS2 before you got this. You will only find it easy if you had THPS2 first.
  10. Hiren
    15 May 2002
  11. vivid
    24 Sep 2001
    will it never end!!
    sure thps3 is good, but i think they should stop sometime soon, tony hawk is getting way to old now anyways
