PSU Too much ram? More juice?
Discussion in 'Hardware' started by MiNiMaL_FuSS, 21 Nov 2011.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    My current system:
    Asus P6T Deluxe
    GTX470 heavily overclocked (higher voltage)
    i7920 @ 4ghz (less than stock volts)
    2 x 2TB Samsung Spin Points
    DVD Writer
    6GB DDR3 XMS3 @ XMP
    Corsair HX520
    The above setup has been perfectly stable for months under any circumstances (can't remember the last crash). 520watt PSU might seem small given today's massive PSU's, but the original HX line were immense PSU's and could handle a hell of a lot, not to mention most big PSU's are just plain overkill.
    Now today I added another 6GB of memory (12GB total), although this isn't an exact match (Patriot Viper) it does match stats-wise and both sets run on the same XMP profile. Since adding in this ram I've experienced 2 system lockups - the screen freezes like a screenshot and nothing moves, crt-alt-delete doesn't work, and a hard reset is necessary.
    My first thought was the ram - but 4 passes of memtest later and it's fine!
    So I'm wondering if I've finally overloaded my psu? Anyway to tell?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    I experienced similar problems when I added extra RAM to an old Evesham PC years ago. Replacing the PSU did correct the problem but we are talking about the rubbish that came bundled with the case Vs a Seasonic!
  3. Shikkari
    Shikkari I know what a Dremel is XD
    19 Feb 2011
    I'm assuming they are all 2GB sticks?
    If so try having the original 6GB plus maybe 2GB of the new sticks, if that's stable try adding another 2GB until you add them all, where it starts crashing could be where you hit your peak?
  4. MiNiMaL_FuSS
    24 Dec 2003
    Yes, 6X2GB sticks.
    I'm doing a PRIME95 on maximum heat and memory strain right now.
    10 minutes in and it's all fine and my CPU has stayed at a nice 55-57c on all cores, which is nice.
    I'll let it run for 20minutes, but really there's not a lot out there that can push a system liek 20minutes of prime.
  5. MiNiMaL_FuSS
    24 Dec 2003
    Sod it, I'm taking the extra ram out for now, it's not worth the the worry, 12GB doesn't seem to actually improve a damn thing anyway!
  6. Blogins
    3 Aug 2010
    If you bought from retail it can be returned for a full refund including delivery postage if you've had it for 7 working days or less starting the day after you took delivery of them under the Distance Selling Regulations assuming it was bought on-line! Read my signature! :thumb:
  7. Guest-44432
    Guest-44432 Guest
    Sounds very much like a PSU overload. Buy your self a plug in watts reader to see what your pulling from the wall under full load.
  8. Shikkari
    19 Feb 2011
    Was thinking that!
  9. MiNiMaL_FuSS
    24 Dec 2003
    it's been in a draw for about 6 months, and that's exactly where it is now.
    I seen to have lost my overclocking lust - I've had a decent stable clock for a long time now and have lost the desire to faf with my pc for hours!
  10. The Protocol
    The Protocol What's a Dremel?
    6 Sep 2011
    Probably won't change anything but have you updated to the latest bios?
  11. Big Elf
    23 Apr 2009
    You might have to increase the QPI voltage a small amount.
  12. Allsopp
    Allsopp What's a Dremel?
    22 Nov 2011
    overclocks can suffer and cause issues when all dimm slots are filled also
  13. The Protocol
    6 Sep 2011
    That, the QPI. Or lower it's frequency if it's anything like the bug generating HyperTransport on this rig
  14. morris8809
    morris8809 Minimodder
    30 Dec 2006
    Have you tried downclocking the cpu some to see if it changes anything?
  15. Speed
    Speed I'm all you need!
    13 May 2004
    More than likely the extra ram is stressing the on board memory controller and the overclock has become unstable. You need to run Prime95 blend or LinX All memory for much longer to rule out the overclock, that or go to stock settings and see if it still crashes.
    More QPI/VTT voltage is usually the cure as mentioned.
