Cooling Too tight?
Discussion in 'Hardware' started by GeorgeK, 16 Feb 2017.
  1. GeorgeK
    18 Sep 2010
    Just playing with the positioning of the 120 radiator on the 980ti hybrid I bought from Speed a little while ago and was after peoples opinions on whether this position meant the bends in the tubing were too tight.
    Cheers!
    GK
  2. Guest-56605
    Guest-56605 Guest
    No that's fine George, if I can run my H80i v2 with no issues whatsoever (as below) then yours is optimum I'd say :thumb:
  3. Parge
    16 Jul 2010
    Hell no, that is 100% fine - in fact you could go much tighter. I whacked two H45s in a Ncase M1 once - that's when you really start worrying about if its too tight.
  4. GeorgeK
    18 Sep 2010
    Awesome - thanks both :D The bend that I was most concerned about was the tube going into the radiator closest to the camera but with a bit of prodding it's possible to get it less tight :)
  5. Vault-Tec
    30 Aug 2015
    EVGA hybrid hoses are stupid long. I had to use clamps on mine to keep them in the PC lol.
  6. GeorgeK
    18 Sep 2010
    They really are aren't they?! Even with the rad right up at the top there they still touch the side window in my case (just)
  7. Vault-Tec
    30 Aug 2015
    Look into hose clamps man. The link in my signature will have everything you need. They're about £4 each IIRC. Look nice too :)
  8. Tangster
    23 May 2009
    it's only too tight if it kinks. :)
  9. TheMadDutchDude
    23 Aug 2013
    As above, it's only too tight if it kinks or flattens the tubing before kinking. :D
  10. GeorgeK
    18 Sep 2010
    Cheers. I presume that the fittings on these units are fairly stong / flexible also then?
  11. TheMadDutchDude
    23 Aug 2013
    The fittings should be fine. You're not bending it at a very harsh angle at the connection anyhow. :)
  12. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    Looks the bomb.
