Modding Tools + Advice :D
Discussion in 'Modding' started by Sean-Blake92, 30 Nov 2014.
  1. Sean-Blake92
    Sean-Blake92 What's a Dremel?
    30 Nov 2014
    hey :) I'm new to the modding scene, but would like to really get involved in it, after seeing some of the amazing things people have made on here, heres the thing I have always loved tech and modding but never had the time to get into it, I work for a big recycling company in Scotland and we deal with all the computers and tech waste, so I have nearly unlimited access to components, materials and cases, so I figured why not use this opportunity to mix the two things i do and enjoy :)
    what I'm really wanting to ask though is this, what are the top 5 Tools you all find yourself using on the mods? what are the tools that are an absolute must? thanks for any replies :)
  2. GeorgeK
    18 Sep 2010
    Moved to Modding as you may get a better response here :thumb:
  3. bulldogjeff
    2 Mar 2010
    For me, in no particular order.
    116mm hole cutter.
    Drill
    Decent screw driver set
    jig saw
    Set of files.
    Obviuosly I use a lot more tools but with that lot you can chop things up, add blow hole?radiators. Gets you going on the more basic stuff
  4. Teelzebub
    27 Nov 2009
    Don't forget a really big hammer lol
  5. bulldogjeff
    2 Mar 2010
    Yeah for when it all goes wrong and the temper tantrums start lol
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    I use a drill, scroll saw, disc sander, files & clamps mostly along with measuring & marking tools, scroll saw could be replaced with a jig saw or even a rotary tool like a dremel.
  7. MarkVarley
    MarkVarley Minimodder
    12 Sep 2014
    Additionally I use my heat gun alot! Best way of doing Heatshrink (except for shrinkless sleeving, which still needs Heatshrink but higher and more concentrated heat) and bending perspex & plexi.
    Also use alot a drill, jigsaw, sander, dremel, soldering iron, loads of screwdrivers with straight philips and hex heads. I have an aluminum ruler with various holes and markings for pc bits from Mnpc. And a Dyson handheld vacuum cleaner!
    Sent from my GT-I9505 using Tapatalk
  8. Sean-Blake92
    30 Nov 2014
    Cheers for the advice people, can't wait to order all my tools so i can start, think I'm going to kick off with a NUC build :)
  9. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    To start out I'd get a Dremel, jig saw, set of files, drill+bits and some quick clamps. I've seen some amazing things done with just those basic tools. I would include a set of hand tools like screw drivers, pliers and a hammer in that list but that's something I think everyone should already have. Then of course once you become hooked you can buy a drill press, various sanders, soldering iron, heat gun, an assortment of hand and power saws, etc... Trust me, it never ends. I always find a reason to buy a new tool :rolleyes:
  10. Sean-Blake92
    30 Nov 2014
    Got my first, and from what I hear most important piece of equipment, a Dremel :D, was pricey but worth it I'm sure, getting there :)
