Tools / Tool kits for Acrylic hard tubes?
Discussion in 'Watercooling' started by kosch, 17 Feb 2021.
  1. kosch
    kosch Trango in the Mango
    12 Feb 2005
    Hi All,
    So I'll be starting my venture into using hard lines for my setup and I was hoping to get some recommendations on all in one tool kits for heating/cutting/bending etc. If such a thing doesn't exist what tools would you recommend?
    Thanks
  2. Yaka
    Yaka Modder
    26 Jun 2005
    i only ever used hard lines for 3 builds i did for freinds and relatives last one was two years ago. i pretty much followed this guide https://bit-tech.net/guides/modding/watercooling/water-cooling-with-hardline-tubing-guide-petg-and-acrylic/1
    used a wickes branded tube cutter and silcone tube were the only things i needed to buy. i dont think its recommended but i just used nails nailed to a bit of thick ply wood to do my bends fair bit of trial and eror and wasted tubes. these days you can get kits like these or these to help you do trippy bends
    didn't realize they added a video to that guide now, should make more easier to understand now
  3. kosch
    12 Feb 2005
    Thanks for the tips @Yaka, I've been watching the video series and its really great. Not sure I will be able to grow a moustache like that though!
    The_Crapman likes this.
  4. Yaka
    Yaka Modder
    26 Jun 2005
    yup i gave it a try but mine started to turn into a bushy mess
    kosch likes this.
  5. kosch
    12 Feb 2005
    I was having a lot of problems making tubes seal properly when I was honing my skills on some test pipes and using a leak tester. After much farting about I discovered my technique with the "lemon squeezer triangle razer blade deburring/chamfer" tool wasn't so good.
    Ended up buying one of these off eBay for a fiver and omg its so easy and also made the pipes slide into the fitting so much easier! Also made me realize that the chamfer needs to be a good 3-5mm on the actual pipe which has been difficult to tell from various videos and guides.
    192944466_174016698061816_2174901522932930612_n.jpg 192471057_475637116877799_5729286378403211197_n.jpg
  6. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    What is it? Got a link?
  7. kosch
    12 Feb 2005
  8. LePhuronn
    6 Oct 2016
    Oh I see. Pair of blades at the bottom of the suspicious-looking shafts, slip the tube over the top to keep it straight and grind away. Nice.
    Shame there's no 12mm equivalent. Would save me designing and printing a guide jig for the lemon squeezer.
  9. kosch
    12 Feb 2005
  10. LePhuronn
    6 Oct 2016
    yeah, saw a couple of those on eBay and Amazon and the very incomplete descriptions seem to indicate the measurements are for ID, not OD, so wouldn't fit my 12/10 tube.
